Baterries in parallel and series
by jonah.seler
Tags: baterries, parallel, series
jonah.seler
jonah.seler is offline
#1
Feb17-13, 09:06 AM
P: 8
Hi.
Lets say I have two batteries{each one has a 12 volts} connected in parallel circuit with a load of 2 ohms.This means,that each battery will force a current of 6A through the circuit and we will have 12 amperes through the circuit.
Is this correct.Does the total amount of amps in the circuit will be 12?
Now what if the battery are connected in series.The the voltage will be 24v ,and with a load of two ohms,the current in the circuit will be 12 amps.So according to this, adding battery in series,increase the current two.The only difference between the two will be in the capacitance.The parallel circuit have two cathodes so it will have more charges, and will last a longer time.Both circuit will have 12 amps, but the parallel will last longer.
I know that I missing something, so if anyone can help... thanks.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
DrZoidberg
DrZoidberg is offline
#2
Feb17-13, 09:26 AM
P: 371
If both batteries are in parallel each one supplies 3A making a total of 6A that flows through the load.
Drakkith
Drakkith is offline
#3
Feb17-13, 12:19 PM
PF Gold
Drakkith's Avatar
P: 11,030
The voltage from batteries in parallel is the same. That is, having two 12 volt batteries in parallel only applies 12 volts to the circuit, not 24. So with 2 ohms of resistance you have 6 amps flowing through the circuit, with 3 amps being supplied by each battery.
In series it is the opposite. Two 12 volt batteries in series supply 24 volts to the circuit. So with a load of 2 ohms you have 12 amps flowing through the circuit.
Register to reply
Related Discussions
Series-parallel or parallel curcuit Engineering, Comp Sci, & Technology Homework 6
Series-Parallel-Series Circuits Introductory Physics Homework 2
Should It Be In Series or Parallel? Introductory Physics Homework 6
Parallel and Series Introductory Physics Homework 3
Resistances in Series, Parallel, and Series-Parallel Combinations Advanced Physics Homework 1
