New Reply
Drip chamber pressure effect effect in fluid administration
Share Thread Thread Tools
Feb18-13, 03:26 AM   #1
Hi ..
I am referring to a a typical IV set administratin of fluids. I am seeing reference in the literature mentioning that bottle height is from the fluid release level to the drip chamber in which you can see some air gap between two level of liquid(call it lower and upper!). According to my understanding, there is liquid in the bottle held above the drip chamber and the height of the liquid in the bottle adds to the atmospheric pressure and acts at the level upper level in the drip chamber. The air in the drip chamber balnaces this which is how the upper liquid level gets defined. The air pressure acting to hold the bottle liquid in the drip chamber will also act on the lower liquid leel in the drip chamber. Therefore the the liquid level in the bottle should also be added to the liquid level in drip chamber to arrive at the effective bottle height at liquid release level.
The literature does not seem to factor the the liquid height in the bottle ? Actual bottle height is what?
Thanks and regards,
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
New Reply
Tags
pressure effects
Thread Tools
Similar Threads for: Drip chamber pressure effect effect in fluid administration
Thread Forum Replies
EFFECT OF Air PRESSURE ON WEIGHT General Physics 9
Effect of increase pipe diameter on fluid General Engineering 11
effect of pressure in a nebula? Astrophysics 1
effect of air pressure on temperature General Physics 8
is the Doppler effect for atomic spectra a purely realistic effect? Special & General Relativity 1
