Final Temp of Water in Calorimeter After Heating Silver Ring
The final temperature of water in a calorimeter after heating a 25.5-gram silver ring at 84 degrees Celsius is determined using the principles of conservation of energy. The specific heat capacity of silver is 234 J/kg·°C, and the calorimeter loses 0.140 kJ of energy to the surroundings. The initial temperature of the water is 24 degrees Celsius, and the calculations confirm that the final temperature can be accurately derived without considering phase changes.
  • Understanding of specific heat capacity and its calculation
  • Knowledge of conservation of energy principles
  • Familiarity with calorimetry concepts
  • Basic algebra for solving equations
  • Study the principles of calorimetry in detail
  • Learn about energy transfer in thermodynamic systems
  • Explore calculations involving specific heat capacities of different materials
  • Investigate the effects of heat loss in calorimetry experiments
Students in physics or chemistry, educators teaching thermodynamics, and anyone involved in experimental calorimetry or thermal energy calculations.
laker88116
A 25.5 gram silver ring ( c=234 J/kg * c) is heated to a temperature of 84 degrees C and then placed in a calorimeter containing 0.05 kg of water at 24 degrees C. The calorimeter is not perfectly insulated and .140 kJ of energy is transferred to the surrounding before a final temperature is reached. What is the final temperature?
Ok, I was thinking that there is no phase change so I am not sure is it just conservation of energy, and if so, how do I start?
Science news on Phys.org
Nevermind, I was able to figure it out.
  • · Replies 27 ·
