Two problems on Electric Fields and Electric Potential
The discussion revolves around two problems related to electric fields and electric potential. The first problem involves finding the electric field from a given electric potential expressed as a dot product and determining the electric potential for a uniform electric field. The second problem examines whether a specified electric field is irrotational and seeks to find the potential function associated with it.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between electric potential and electric field, questioning whether to use Cartesian or spherical coordinates. There is discussion on the application of the gradient operator and the implications of integrating to find potential. Some participants express uncertainty about line integrals and the use of Stokes' theorem.
Participants are actively engaging with the problems, offering suggestions and clarifications. Some guidance has been provided regarding the integration process and the need to consider constants of integration. Multiple interpretations of the second problem are being explored, particularly in relation to concepts from ordinary differential equations.
Some participants mention their lack of confidence in vector calculus, which may be impacting their ability to tackle the problems effectively. There is also a recognition of the need for clarity on the definitions and relationships between the components of the electric field and potential.
Momentous
1st Problem
(a) Consider the electric potential V = C . r, where C is a constant vector. Find the electric field E(r).
(b) For a given uniform electric field E = E(0)z^, using part (a) find the electric potential for this electric field
2nd Problem
Consider the field E = (2x^2 - 2xy - 2y^2)x^ + (-x^2 -4xy + y^2)y^. Is this field irrotational? If so, what is the potential function?
A.B = ABcosθ
Curl = ∇ X V (any vector V)
E = -∇V
V = -∫ E.dI
1st Problem
First I wrote down V as a dot product
V = Crcosθ
Next, I figured that I should use E = -∇V
I'm not show how I would do this, with r and θ
Would converting to spherical coordinates help here? Or did I just mess up from the beginning?
2nd Problem
I am aware that a vector is irrotational when ∇ X V = 0
I know that I have to take the curl of this vector, and it will equal 0.
Next, I was going to use
V = -∫ E.dI
The only issue is that it's been a long time since I've done a line integral. The electric field vector is written in vector notation, but is that how I put it into the integral? Part of me feels that I have to use stokes theorem, but I'm not exactly sure what I'd do from there. Since ∇ X E = 0, wouldn't Stokes theorem give me a double integral of 0?
My vector calc is very rusty, so I think that's the area that's messing me up with these problems.
Thank you for your time!
Momentous said:
1st Problem
I would suggest sticking with Cartesian coordinates. Can you write out the dot product [itex]\vec{C}[/itex][itex]\cdot[/itex][itex]\vec{r}[/itex] in Cartesian coordinates?
2nd Problem
V = -∫ E.dI
How is the x-component of E related to V? How is the y-component of E related to V?
Can you see a way to find V from these relations?
Well I guess the dot product in Cartesian is just
C(x)r(x) + C(y)r(y) + C(z)r(z)
From that, I would do E = -∇V, if that makes any sense.
For the second problem, I'm not really sure what you mean by that. I know that you can integrate to find V, but again I'm not really sure how I can do that.
Yes, that's right. You should find that E has a simple relation to the vector C.
From E = -∇V, you have ∂V/x= -Ex, where Ex is given. See if you can integrate this with respect to x while keeping y constant.
hmm ok, so then if I took the negative gradient of that dot product, I would assume that I would get
E = -C(x)v(x) - C(y)v(y) - C(z)v(z)
when taking the derivative of the position vector. Unless it's not a time derivative, then I guess I would just leave it once I put in the gradient notation.
So then if I did it separately, I would have
V(x) = [-(2x^3)/3 + yx^2 + 2xy^2]
V(y) = [yx^2 + 2xy^2 - (y^3)/3]
V = V(x) + V(y) = 2yx^2 + 4xy^2 - (2/3)x^3 - (y^3)/3
That seems close, but when I take the partial derivatives I don't get exactly what I started with. I think I messed up in a spot or two
It's not a time derivative. The gradient here involves spatial derivatives. Note that the x,y,z components of the vector ##\vec{r}## are just x, y, and z. So, what you wrote as r(x) is just x, etc. Hence ##\vec{C}\cdot \vec{r} = C_x x+C_y y + C_z z##
This isn't quite the way to do it. You started out ok. When you integrate Ex = -∂V/∂x you must allow for a "constant" of integration. Since you are keeping y constant as you integrate, the "constant" of integration can actually be an arbitrary function of y, say f(y).
So, you will get V(x,y) = -2x3/3 + yx2 + 2xy2 + f(y).
To find the function f(y), set -∂V(x,y)/∂y = -Ey which should allow you to find an expression for f '(y) which you can then integrate to find f(y).
Oh alright, that makes a lot more sense
Is that second problem basically the same as testing for exactness in ODE?
Yes, exactly :smile:
  • · Replies 17 ·
