Register to reply
Three Point Charges, find the electric force exerted
by m00nbeam360
Tags: charges, electric, exerted, force, point
Share this thread:
m00nbeam360
#1
Feb19-13, 09:40 PM
P: 20
Three charges, each of magnitude 2 nC, are at separate corners of a square of edge length 1 cm. The two charges at opposite corners are positive, and the other charge is negative. Find the force exerted by these charges on a fourth charge q = +3 nC at the remaining (upper right) corner. (Assume the +x axis is directed to the right and the +y axis is directed upward.)
2. Relevant equations
k = (8.988*10^9 N*m^2/C^2)
3. The attempt at a solution
Drew a diagram of the problem such that F4 = F1,4 + F2,4 + F 3,4.
F1,4 = (k*q1*q4)/(r(1,4)^2)j
F1,4 = (8.988*10^9 N*m^2/C^2)(2.00*10^-9)*((2.00*10^-9)/(0.01m)^2)
= 3.595 * 10^-4 j
F2,4 = same
F3,4 = (k*q1*q2)/(r(2,4)^2)*r(3,4)
r(3,4) = r(3,1) + r(1,4) = (0.01m)i + (0.01m)j
r(3,4) = (0.01m)i+(0.01m)j/(sqrt(0.01m^2+0.01m^2)) = 0.14i + 0.14j
F3,4 = (8.988*10^9) (-2.00*10^-9)(2.00*10^-9)/(0.01sqrt(2)^2)*(0.14i+0.14j)
= -2.52 * 10 ^ -5
(3.595 * 10^-4) i - (-2.52*10^-5) i = 3.34*10^-4i <--- Wrong :(
(3.595 * 10^-4) j - (-2.52*10^-5) j = 3.34*10^-4j <--- Wrong :(
Any suggestions?? I think that somewhere in computing F3,4 I put in an incorrect number. Thanks!
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
TSny
#2
Feb19-13, 10:11 PM
HW Helper
Thanks
P: 4,844
Quote Quote by m00nbeam360 View Post
Check this.
m00nbeam360
#3
Feb19-13, 10:30 PM
P: 20
Whoa, got .707 now, thanks. So then is everything else correct?
TSny
#4
Feb19-13, 11:18 PM
HW Helper
Thanks
P: 4,844
= 3.595 * 10^-4 j
Did you use the correct value for q4 here?
Register to reply
Related Discussions
Finding r using point charges and work done by an electric force Introductory Physics Homework 2
Electric force due to point charges Introductory Physics Homework 0
Force exerted by two charges Introductory Physics Homework 2
Electric force between two point charges Introductory Physics Homework 2
Net force exerted by two charges on a 3rd charge Introductory Physics Homework 1
