Register to reply
Simple energy calculation help
by bgizzle
Tags: calculation, energy, simple
Share this thread:
bgizzle
#1
Feb20-13, 09:55 AM
P: 22
Hi,
I'm trying to calculate theoretical energy generated by a system and I'm not sure if I'm doing it right and if I understand the concept properly. Here is my thinking, any input is appreciated.
12 billion joules of energy generated over 1800 seconds
equals roughly 6.8 million watts by dividing 12 billion by 1800
6.8 million watts * 8765 hours in a year = 60 billion watt hours/year
or is it .00027777*12 billion joules=3.5 million watt hours then 3.5 million * 8765 hours in a year = 30 billion whr/year
so basically i have joules of energy generated over a period of time, how do I convert that into total energy generated over the course of a year. I'm struggling with how to properly translate the different time periods into standard units of energy.
Appreciate any help.
Phys.Org News Partner Physics news on Phys.org
Scientists uncover clues to role of magnetism in iron-based superconductors
Researchers find first direct evidence of 'spin symmetry' in atoms
X-ray laser probes tiny quantum tornadoes in superfluid droplets
deep838
#2
Feb20-13, 12:02 PM
P: 108
Okay, first of all, is it so hard for you to work using powers of 10??? Or do you like to writing big?
Now, you have some energy (W) which you have generated in a period of time (t) and hence you can find the power (P) generated, by P = W/t , ie, P = 12*109J / 1800 sec, ie, P = 6.67*106 watt.
If you need the energy created in a year, just multiply P with one year in seconds...
1 year = 365*24*60*60 sec = 3.1536*107 sec
So the net energy produced in a year, E = P*3.1536*107 sec, ie, E = 2.1024*1014 J.
If you want it in watt.hr-1.yr-1 then your first answer should be alright. But in your second answer, what is 0.00027777 you are multiplying with? I don't think its correct and so you are getting two different answers!
bgizzle
#3
Feb20-13, 12:22 PM
P: 22
So how do I convert your joule number of 2.1024x10^14 to watt hours per year properly?
the first part of your calculation is in watts: 6.67*10^6 but when you multiplied it by seconds in a year your result was in joules, is that right?
lol, sorry for some reason I like big numbers.
mfb
#4
Feb20-13, 12:40 PM
Mentor
P: 11,831
1W*1yr =1W*3.14*107s = 3.14*107*W*s = 3.14*107 J
Just convert units, there is no need to multiply any value with another value.
bgizzle
#5
Feb20-13, 01:30 PM
P: 22
Quote Quote by mfb View Post
If I understand you correctly (doubtful) then I divide 12 billion joules by 1800 seconds and get 6.8 million watts which i then multiply by 3.14*10^7 to get watt hours per year which i then divide by 1,000,000,000,000 to get twh/year of 217. I'm pretty sure that is wrong but hoping its right.
I'm not sure I understand (I have no formal physics background), at this point I am pretty thoroughly confused. I would like to know: 12 billion joules of energy generated over 1800 seconds would lead to how many terawatt hours generated over the course of a year. Without a firm answer or a very comprehensive explanation I cannot reverse engineer it so I can understand it. If you would like to change the original joules and seconds that is fine.
Thanks for your post.
etudiant
#6
Feb20-13, 02:25 PM
PF Gold
P: 860
Hi bgizzle,
I think you would want to give mbf and deep838 credit, they show you the answer but do keep it compact.
You have 12x10**9 joules in 1.8x10**3 seconds is 6.8x10**5 watts.
You have 3.1536x10**7 seconds/yr, so you generate overall 6.8x3.1536x10**12 watts each year.
Divide that by 3600sec/hr and again by 10**12 and that is your terawatt hours/year.
The key is to keep good track of the dimensions, joules measure energy, watts measure energy/second ie power. That is why dimensions such as terawatt hours/year are really ambiguous and confusing. They simplify the language but confuse the realities of the matter.
bgizzle
#7
Feb20-13, 02:52 PM
P: 22
Quote Quote by etudiant View Post
Hi bgizzle,
Ok, thanks for your response, not sure why you think I wasn't giving them credit. So if I understand you correctly the final answer is approximately .06 twh/year (6.0x10^-2). You multiply in all the seconds in a year but then divide out the seconds in an hour to get the units in terms of watt hours/year.
deep838
#8
Feb20-13, 11:58 PM
P: 108
Quote Quote by bgizzle View Post
Of course it's right... Watt is Joules/sec, so on multiplying Watt with sec, I get back to Joules!
If you need watt-hrs, which by the way is also energy, just multiply P with 1 hr...
And then if you need watt-hrs/yr, which is again power, multiply with the number of hours in 1 yr and then divide P*365*24 hr by 1 yr...
Conversion from one unit to the other is not a special facility for physics, its just mathematics... more of arithmetic actually. Only the terms and names if the units come from physics in this case!
deep838
#9
Feb21-13, 12:02 AM
P: 108
Hi bgizzle,
No, that's not watt/yr ! That's Joules/yr !
Because 1 watt is DEFINED to be Joules/sec .
bgizzle
#10
Feb21-13, 01:00 PM
P: 22
Quote Quote by deep838 View Post
Ok, thanks for all your help. I believe I understand it now.
Register to reply
Related Discussions
Simple Q-value calculation for n+14N -> 12C + t Introductory Physics Homework 4
Simple Free Energy calculation given Pressure and concentration Biology, Chemistry & Other Homework 0
Simple Power calculation Introductory Physics Homework 4
Can all basic energy question be calculation without energy formulas & by using f=ma Classical Physics 8
Simple entropy calculation Introductory Physics Homework 6
