Register to reply
Net Force and Net Work
by Yosty22
Tags: force, work
Share this thread:
Yosty22
#1
Feb21-13, 07:45 PM
P: 143
First, let us consider a sled of mass m being pulled by a constant, horizontal force of magnitude F along a rough, horizontal surface. The sled is speeding up.
Let us now consider the situation quantitatively. Let the mass of the sled be m and the magnitude of the net force acting on the sled be F. The sled starts from rest.
Consider an interval of time during which the sled covers a distance s and the speed of the sled increases from v1 to v2. We will use this information to find the relationship between the work done by the net force (otherwise known as the net work) and the change in the kinetic energy of the sled
Use W=Fscos(θ) to find the net work Wnet done on the sled. Express your answer in terms of some or all of the variables m, v1 and v2.
2. Relevant equations
W=Fscos(θ)
K=1/2mv2
ƩF=ma
3. The attempt at a solution
The only thing I could do so far is the equation for Fnet. The equation is unsimplified, so it is a little messy, but I attatched a picture of the Fnet equation.
Since Wnet=Fnets, I assumed that if you multiply by s, the distance, then the s would cancel out and you would be left with the net force equation without the s in there. However, I'm very confused by what it is asking. It says that W=Fscos(θ), but the answer cannot have the variable θ in there. The only thing I could think of is that since it is being pulled on a flat surface, then cos(180)=-1, but since the sled is speeding up in the direction of the net force, work has to be positive. I cannot figure out what I should do next to try to solve this.
Thank you in advance for the help.
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
rude man
#2
Feb21-13, 08:48 PM
HW Helper
Thanks
PF Gold
rude man's Avatar
P: 4,759
You obviously would like s, the distance covered when the velocity reaches v, expressed as a function of v. Then you can say
Δs = s(v2) - s(v1)
and then W = Fcos(θ)Δs. (it should be obvious what θ is here. It's the angle between the force vector and s. And, it's positive since F and s go in the same direction. You nearly got that one right).
What is F in terms of a? Everyone knows that one! Newton knew it over 200 yrs. ago!
So how do we get s(v)?
Hint: use chain rule to get dv/ds and integrate both sides of an easy differential equation in s, v and constants. t is eliminated by the chain rule. Or maybe you already have a formula handy for coming up with s(v).
When you get your answer you should compare it with the difference in kinetic energies of the sled at v1 and v2.
Register to reply
Related Discussions
Sum of work = Work done by net force Classical Physics 1
Work to push a sled up a hill: Friction, inclines,force,work Introductory Physics Homework 2
Work Done by Force Introductory Physics Homework 2
Force and Work Introductory Physics Homework 5
Force / Work Introductory Physics Homework 2
