What Is the Role of Flux in Electromagnetic Induction?
  • Context: Undergrad
  • Thread starter Thread starter Geoffrey F. Miller
    Flux
The discussion focuses on the role of flux in electromagnetic induction, specifically through the example of a magnet dropped through a coil. It clarifies that an electromotive force (emf) is the induced voltage resulting from changes in magnetic flux, as described by Faraday's Law of Induction. The conversation confirms that while incoming and outgoing fluxes may be equal and opposite, they occur at different times, leading to a directional potential difference. The units of flux are not explicitly stated but are typically measured in Webers (Wb).
  • Understanding of Faraday's Law of Induction
  • Basic knowledge of electromotive force (emf)
  • Familiarity with magnetic flux concepts
  • Knowledge of units of measurement in electromagnetism
  • Research the mathematical formulation of Faraday's Law of Induction
  • Study the concept of magnetic flux and its units (Webers)
  • Explore the relationship between emf and magnetic field changes
  • Investigate practical applications of electromagnetic induction in technology
Students of physics, electrical engineers, and anyone interested in understanding the principles of electromagnetic induction and its applications in real-world scenarios.
Geoffrey F. Miller
Okay. Let's say you have a coil. You drop a magnet through it, which induces an emf (please explain what exactly an emf is). So, somehow Faraday's Law of Induction comes into play (please explain this law to me). Now you have an incoming and outgoing flux, right (I have no idea what this means)? I'm guessing that the incoming and outgoing flux are equal but opposite. Am I correct? What are the units of a flux? Why are the fluxes equal, that is, if they really are?
Please help me.
Most of your questions can be answered by carefully reading your text. At least that would give you some basic knowledge to build on.
An emf (archaic terminology meaning electo-motive force) is simply an induced potential difference or voltage between two points. Flux, or lines of force, is a purely geometrical model that helps us to think about magnetic fields. It not physically real.
If you think about lines of force around the magnet cutting across the loops of the wire, Faraday's law says that this induces (creates at a distance) a potential difference between the ends of the wire. The incoming and outgoing fluxes may be equal and opposite but they 'cut' at different times so the potential difference across the wires is in one direction as the magnet approaches the center of the coil and the other direction as it leaves.
AM
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 25 ·
