| New Reply |
about spring constant and Hooke's law |
Share Thread | Thread Tools |
| Feb25-13, 05:15 PM | #1 |
Hi all,
I am reading an online material on elastic force and Hooke's law on spring. The definition of the Hooke's law reads that the restoring force is linear proportional to the displacement of the spring with constant k. The restoring force is defined as the force bringing the object back to the equilibrium position and k characterize the system's (spring's) nature. So if we have a spring with equilibrium position sitting in the origin of the coordinate so the restoring force F satisfies $$F = -k x$$ Now, if there is a way to add a second force ($F'$) which is exactly the same as $F$ (same direction and magnitude), since $F'$ is along $F$ all the time, so $F'$ always pointing toward the equilibrium position too. In this sense, should I conclude that $$F+F' = 2F = -k' x$$ if so, can we say that by adding an additional force $F'$, the spring constant k changed to k'=k/2 ? But I think the spring constant should be given by the spring only, so how does the paradox come from? |
| Feb25-13, 05:18 PM | #2 |
Recognitions:
The spring constant k will be constant for a spring of given dimensions.
If you have a force F applied on the spring such that F = kx and you apply a second identical force then the extension 'x' will just double as well. |
| Feb25-13, 05:24 PM | #3 |
| New Reply |
| Thread Tools | |
Similar Threads for: about spring constant and Hooke's law
| Hooke's law = negative spring constant? | Introductory Physics Homework | 5 | ||
| Hooke's Law. Does this spring... | Introductory Physics Homework | 4 | ||
| Spring and hooke's law | Classical Physics | 1 | ||
| Ideal Spring and Real Spring Difference? (Hooke's Law) | Introductory Physics Homework | 10 | ||
| Hooke's law with spring | Introductory Physics Homework | 2 | ||
