Current in the primary coil of transformers used in rectifier circuits
The current in the primary coil of transformers used in full wave rectifier circuits adheres to the relationship V(s)I(s) = V(p)I(p), but the specific values to use depend on the calculation required. For peak and RMS current calculations, the peak voltage is applicable, while the average current over a complete cycle mathematically results in zero due to the sine wave nature of the current. Understanding these principles is essential for accurate transformer current analysis.
  • Understanding of transformer operation in electrical circuits
  • Knowledge of full wave rectifier circuits
  • Familiarity with peak and RMS voltage/current calculations
  • Basic grasp of sine wave functions and their properties
  • Research transformer primary coil current calculations in detail
  • Learn about full wave rectifier circuit design and analysis
  • Study the differences between peak, RMS, and average values in AC circuits
  • Explore the mathematical properties of sine wave functions in electrical engineering
Electrical engineers, students studying circuit design, and professionals involved in transformer and rectifier circuit analysis will benefit from this discussion.
egnrbyaccident
Can anyone please clarify if the current in the primary coil of the transformer follows V(s)I(s)=V(p)I(p) when i am trying to figure out the peak, surge and average current through the primary coil of a transformer in a full wave rectifier.
Also, if it does, do I just use the peak voltage or the rms value?
It does and it does not . That depends on what are u trying to calculate.
You can use this relationship to calculate the "peak" voltage / current and R.M.S value , depending on what you need.
One more thing, as long as the average current or voltage is concerned it would mathematically be zero since the Current is a sine wave function . The mean value of such a current over one complete cycle would be zero .
  • · Replies 81 ·
9K
9K
  • · Replies 48 ·
9K
  • · Replies 28 ·
