Radial vs Axial Turbine, diff in mechanical stress
by Chuck 65
Tags: axial, diff, mechanical, radial, stress, turbine
Chuck 65
Chuck 65 is offline
#1
Feb26-13, 06:19 PM
P: 1
I am a hobbyist and I have designed a radial turbine device for use in a tidal stream. I have conducted a couple of experiments to demonstrate that there is less mechanical stress in the radial approach as compared to the axial approach but I would like to prove this concept mathematically (at a basic level). I have been able to find references to Eulers equation but (not being an engineer or physicist) am unable to figure out how to use the formula to show the difference. Can someone out there please explain the basic math principles that show why an axial turbine will have more mechanical stresses than a radial turbine?
W=(U2-U1) + (V2-V1) + (W2-W1) where U = Blade velocity, V = Absolute Velocity, W = Relative Velocity.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
Register to reply
Related Discussions
Calculation of Thrust/Axial loads on Cantilever Turbine Shaft Mechanical Engineering 0
axial stress rate vs axial strain rate Engineering, Comp Sci, & Technology Homework 0
Axial stress Introductory Physics Homework 13
Maximun axial stress Engineering, Comp Sci, & Technology Homework 2
Stress, Strain - Axial loading (axial forces) Mechanical Engineering 11
