Register to reply
Slingshot Physics
by FredericChopin
Tags: physics, slingshot
Share this thread:
FredericChopin
#1
Mar4-13, 03:41 AM
P: 57
I am investigating how the displacement of an elastic band affects the distance an attached object will travel (the relationship between how far back you pull a slingshot and the distance an object will travel). What I am trying to do is find a formula where distance travelled is a function of elastic band displacement (in other words, a formula which says "x = ... d..."), but I ended up very confused. I tried equation manipulation with the following equations:
W = F*d
W = ΔEKinetic
EKinetic = (1/2)*m*v2
and
EElastic Potential = (1/2)*k*x2
I got close to the final equation, but I couldn't make it. Here are a few things to keep in mind:
* In the final equation, where "x = ... d...", I don't want the force, F, to be in the equation.
* We are assuming that initial kinetic energy was 0 (meaning that the initial velocity was 0).
* We are assuming that the effects of friction and air resistance are negligible.
Thank you.
Phys.Org News Partner Physics news on Phys.org
On-chip topological light: First measurements of transmission and delay
A two-stage trap for single protons leads to measurement of their magnetic properties
Unexpected phenomenon discovered at the surface of a transition metal oxide material
jedishrfu
#2
Mar4-13, 04:05 AM
P: 2,817
I don't think the F of the elastic band is constant with distance.
You could try hooke's law on it and measure the F values for various distances of pullback.
Then you can use that to compute the work involved.
e.chaniotakis
#3
Mar4-13, 04:38 PM
P: 72
I didn't quite understand the question..
rcgldr
#4
Mar4-13, 05:37 PM
HW Helper
P: 7,055
Slingshot Physics
Quote Quote by FredericChopin View Post
You won't need F, but you will need the "sprint constant" k for the sling shot. Note this is an approximation, since the graph of force versus stretch of rubber bands is not a straight line, but a curve. Example graph from a wiki article, which is also somewhat idealized. Usually the slope for the initial stretch is steeper, then decreases to a near straight line, then increases again at the limit of stretch (permanent deformation can occur if stretched close to the limit):
Elastic_hysteresis.htm
Archived web page showing a stretch versus tension graph for latex rubber used to launch radio control gliders (tension at 300% is about 175 lbs per square inch cross sectional area):
rubberdata.htm
FredericChopin
#5
Mar5-13, 02:57 AM
P: 57
Thank you very much, but I have found a solution:
First, due to conservation of energy, the elastic potential energy of the elastic band is equal to the kinetic energy of release. So:
(1/2)*k*x2 = (1/2)*m*v2
(1/2)*x2 = (m*v2)/(2k)
x2 = (2m*v2)/(2k)
x = √((m*v2)/(k))
By finding v2 using the equations of motion, the mass, m, will be the function of spring displacement, x, while v2 and k remain constant (v2 will change depending on the desired displacement for the object to travel in the x or y axis).
Register to reply
Related Discussions
Physics problem - slingshot Introductory Physics Homework 3
Slingshot Lab Introductory Physics Homework 0
Giant Slingshot General Physics 4
Physics Slingshot Project Help General Physics 3
Interesting Physics Project: Slingshot car Introductory Physics Homework 2
