Graphes: Increasing/Decreasing, Concave Up/Down, Inflection Points?
  • Context: Undergrad
  • Thread starter Thread starter sjaguar13
    Concave Points
The discussion revolves around the relationships between a function and its first and second derivatives, particularly focusing on increasing and decreasing intervals, concavity, and inflection points. Participants explore these concepts through both graphical and algebraic perspectives, raising questions about definitions and implications of derivative behavior.
  • Some participants question whether the intervals where the first derivative f' is decreasing correspond to the intervals where the function f is decreasing, with examples provided.
  • There is a discussion about the mathematical definition of a function being decreasing, with some participants asserting that it relates to the behavior of the derivative.
  • One participant suggests that if f' < 0, then f is decreasing, and if f' is decreasing, then f is concave down, while also discussing conditions for local maxima and minima.
  • Another participant raises a specific example involving the function f(x) = sin(πx) and questions the nature of the critical point at x = 1/2, seeking clarification on whether it represents a maximum, minimum, or inflection point.
  • There is confusion expressed by participants regarding the implications of critical points and the importance of the point x-1 in determining local extrema.
Participants express differing views on the relationships between the behavior of a function and its derivatives, particularly regarding definitions and implications of decreasing intervals and critical points. The discussion remains unresolved with multiple competing perspectives.
Participants rely on definitions and interpretations of decreasing functions, concavity, and critical points, which may vary. There are unresolved mathematical steps and assumptions regarding the behavior of derivatives and their implications.
sjaguar13
If I had a graph of f', would the intervals where f' is decreasing be the same as the intervals where f is decreasing? For example, the graph of f' is degreasing from -1 to 0. Is f decreasing from -1 to 0 also?
With the same graph of f', how would you know on which intervals f is concave up or down? Would I need to find f'' and how would I do that with just the graph?
Same thing with the inflection points, would I need f''?
If I didn't have a graph, just the equation of f', would I find the intervals of increasing and degreasing by finding what numbers make f' = 0, and check wether those numbers if put back into the equation come out positive or negative?
No, let [tex]f=C-x^{2}[/tex]
f is increasing on [-1,0], whereas f' is decreasing there.
What does it mean that a function is decreasing?
What is the mathematical definition of "decreasing"?
What does it mean that a function is decreasing? From left to right, x is getting smaller
What is the mathematical definition of "decreasing"? I assume the same thing.
Let's take the case of a differentiable function:
Given a function f(x), what is the sign of its derivative, f'(x), when f is decreasing?
I think I got this. If f'<0, f is decreasing. If f' is decreasing, f is concave down. If f'(x) = 0, then x is either a local max or min. It's min if f'(x-1) < 0 and max if f'(x-1) > 0. The inflection points will be where the direction of concavity changes, so it's going to be the endpoints of the intervals, like concave up on (2,5)U(7,10) and down on (0,2)U(5,7) then inflection points would be 2,5,7 (not 2 and 10 because the are end points).
Why do you think the point [tex]x-1[/tex] is so important? Let's say my function is
[tex]f(x) = \sin{(\pi x)}[/tex]
does the critical point at [tex]x = \frac{1}{2}[/tex] represent a minimum, maximum, or point of inflection, according to your method? What is it really?
...I'm confused.
Do you agree that [tex]\sin (\pi x)[/tex] has a critical point (ie. a point where [tex]f^\prime = 0[/tex]) at [tex]x = \frac{1}{2}[/tex]?
If so, all I want to know is: does this critical point represent a maximum, a minimum, or a point of inflection?
  • · Replies 19 ·
