Performance gains above 1600MHz RAM
  • Thread starter Thread starter Kutt
    performance Ram
The discussion revolves around the performance implications of using RAM above 1600MHz in enthusiast desktop systems. Participants explore the relevance of JEDEC standards, overclocking methods, potential risks associated with voltage increases, and the comparative benefits of memory speed versus capacity.
  • Some participants suggest that performance gains from RAM above 1600MHz are minimal and primarily beneficial during overclocking.
  • JEDEC is mentioned as an industry standard that dictates default RAM speeds, with participants using analogies to explain how RAM operates at these speeds without overclocking.
  • One participant notes that their motherboard only supports a maximum of 1600MHz RAM without overclocking.
  • There is a discussion about the ease of overclocking RAM, with methods including increasing clock speed or reducing CAS latency cycles.
  • Concerns are raised about the risks of using RAM with voltages above 1.5V, particularly regarding potential damage to Ivy Bridge processors and the lifespan of components due to overvolting.
  • Another participant argues that increasing memory capacity generally provides a more significant performance boost than simply increasing memory speed.
Participants express differing views on the benefits of higher RAM speeds versus capacity, and there is no consensus on the ease of overclocking or the risks associated with voltage increases.
Participants discuss various assumptions regarding RAM performance, overclocking techniques, and the implications of voltage adjustments, but these points remain unresolved and depend on specific hardware configurations.
Kutt
I was told that performance gains using memory above 1600MHz in enthusiast desktops is very small and unnoticeable, and is only useful when overclocking.
This has something to do with "JDEC" what is JDEC?
Computer science news on Phys.org
JEDEC - http://en.wikipedia.org/wiki/JEDEC
It's an industry standard that everyone follows to make stuff work with each other.
The simplest way i can think of to explain RAM frequency is like this.
Imagine you have 3 cars.
A toyota corolla (cheap), a ford mustang(little expensive) and a ferrari (very expensive)
When you drive them on the highway you have to follow the speed limit 110 km/h
doesn't matter what car you get, all of them MUST obey the speed limit.
this is how ram works.
you can buy 1333MHz ram(cheap) or 1600MHz ram (little expensive) or 2666MHz ram(very expensive)
by default (no overclocking) all of them run at 1333MHz - this is the default DDR speed (your normal speed limit)
if you want a ferrari to go at 250 km/h you have to step on the gas.
if you want your 2666MHz ram to operate at 2666MHz, you have to overclock the system.
by default your 2666MHz ram will operate at 1333MHz when plugged into a system and it will have no performance benefits over regular ram operating at 1333MHz
its like having a ferrari driving at 110km/h on the highway, yes you will look good getting there but the corolla will get you there in exactly the same time. The difference only comes into play if you actually speed or in the RAM's case, you overclock.
Is it easy to overclock memory?
There are two main methods to speed up the memory from the system default. One is to run a faster clock speed, the other is to use the same clock speed, but use fewer cas latency cycles to access the ram, for example, from CL9 (9-9-9-24) down to CL7 (7-7-7-20), or a combination of both. Here'a link to the previous thread on this:
https://www.physicsforums.com/showthread.php?t=671713
Someone told me that the Ivy Bridge processor and chipset can be damaged if you use memory above 1.5V
The on-die memory controller can be fried.
Applying more voltage than spec will reduce the lifespan of your components. How much? that depends on the amount you over volt. You will need to do some research to find out specifics. But in most cases, a CPU that may last for 8-10 years will only last for 5-6 years. Doesn't really make that big of a difference given most people upgrade their systems in 3-4 years.
Over volting also carries the danger of burning out the component in question but this is rare and doesn't happen very often.
Your main enemy is heat. Overclocking = more heat generation. Small overclocks (5%) can be done with stock cooling. The overall heat generation doesn't increase enough to exceed the capacity of your heatsink/fan but if you are trying to achieve a nominal overclock, you will need to invest in an aftermarket cooling solution (new heatsink/fan)
Generally, and particularly if you are running multiple applications, MORE memory will get you a much greater performance boost than faster memory.
  • · Replies 58 ·
