Register to reply
Statics: Find resultant force and couple moment
by Chandasouk
Tags: couple, force, moment, resultant, statics
Share this thread:
Chandasouk
#1
Mar9-13, 06:02 PM
P: 165
Calculate the resultant force’s magnitude and the couple moment.
Let a = 3.70 m
w1=5.35kN/m
w2=4.00kN/m
The resultant force of the triangle is 1/2(3.70)(5.35)=9.898 kN
The resultant force of the rectangle is (4)(3.70) = 14.8kN
So FR (The force's magnitude) is 24.69kN
I found the location of the triangle's load to be 1/3(3.7) = 1.233m
I found the location of the rectangles load to be 1/2(3.70)+3.7 = 5.550m
So I calculated the couple moment MRa (Taking counter clockwise to be POSITIVE) I get
(9.898)(1.233)+(14.8)(5.55) = 94.3kN*m
but when I put these answers down for MasteringEngineering, they are incorrect. Where did I go wrong?
Phys.Org News Partner Science news on Phys.org
Sapphire talk enlivens guesswork over iPhone 6
Geneticists offer clues to better rice, tomato crops
UConn makes 3-D copies of antique instrument parts
haruspex
#2
Mar9-13, 06:36 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,645
W1 and W2 are acting in opposite directions.
Even if you correct that your FR calculation will still be wrong. You don't want the total vertical force. You only want the load at A. To get that, take moments about B.
When you take moments about A for the second part, W1 has a negative moment. (I assume it's only asking for the moment about A due to W1 and W2. If the joint at B is holding the beam then there will also be a moment from that, and the total moment will be zero.)
haruspex
#3
Mar9-13, 06:36 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 9,645
Register to reply
Related Discussions
Statics Question: Finding Resultant Moment Engineering, Comp Sci, & Technology Homework 1
Finding the resultant couple moment Introductory Physics Homework 1
Statics - Balancing moment and resultant force Introductory Physics Homework 1
Find the Moment (Torque) of the resultant in 3-D (Statics) Engineering, Comp Sci, & Technology Homework 5
How to get mag. & angles of resultant couple moment Introductory Physics Homework 1
