Statics, determine the force required to rotate a body
The discussion focuses on determining the forces required to rotate a body in a statics problem. The user identifies three forces acting on the body: the force Fb, reaction at point O on the x-axis (Rox), and reaction at point C on the x-axis (Rcx). Through calculations, the user concludes that Rcx equals 8.75N and identifies the force P required to initiate rotation as 5.83N, while grappling with the implications of forces acting on the y-axis and the conditions for static equilibrium.
  • Understanding of static equilibrium principles, including Sum Forces=0 and Sum Moments=0.
  • Familiarity with free body diagrams and their application in statics problems.
  • Knowledge of reaction forces and their roles in determining system stability.
  • Basic proficiency in solving systems of equations related to forces and moments.
  • Study the concept of free body diagrams in greater detail to enhance problem-solving skills.
  • Learn about the conditions for static equilibrium in two-dimensional systems.
  • Explore the role of friction forces in statics and how they affect equilibrium calculations.
  • Investigate advanced topics in statics, such as the effects of multiple forces and moments on rigid bodies.
This discussion is beneficial for students studying statics, mechanical engineers, and anyone involved in analyzing forces and moments in physical systems.
jonjacson
I´ll use a picture to show the problem:
Sum forces=0
Sum Moments=0
Basically I´m not sure about the forces on the free body diagram and I´d like to talk about them.
Assuming that P is not acting, and the body is masless these are the only three forces acting on it: Fb, reaction at O on the x-axis Rox, and reaction at C on the x-axis too Rcx, Am I right?
I know that is not what the problem is asking, it´s only to make this clear, solving the equations it´s pretty easy:
Sum Fy= there are not any forces on this axis
Sum Fx=> Rcx + Nox =Fb
Sum Mc= Fb*40=Nox*80----> Nox=1750*10/1000*2=17.5N
Rcx=8.75N
Is everything right until here?
Now, assuming a force P must be acting on the body to start rotation, I´m a bit lost with forces, basically on the y axis.
I thought that at the point C a force on the y-axis cannot act, but then I thought that maybe it was possible. For example, if you push an object against a wall it doesn´t fall, you are applying a force on the x axis, there is a reaction force at that axis, but there must be a friction force on the y-axis with the same modulus as the gravity, well I think that´s the only option to guarantee that the statics equations are correctly used.
So, let´s suppose that we have a general force at the point C, and we don´t know its direction, we have three unknown quantities: P, Rcx, Rcy.
Now If I look to point O, I think that due to Fk there must be a reaction on the x axis, but I´m not sure if there could be a reaction on the y axis.
ANyway I have more unknown quantities Rox, Roy.
I have a total of 5 unknown quantities and three equations, so I can´t solve the system, but the book gives me a numerical answer, so I think that I should make two assumtions, maybe that Rcy is 0, and Roy is 0 too, but in that case for the y-axis I have:
SUm Forces Y axis= P=0, which doesn´t make any sense.
So, Is the system able to create reaction forces on the Y axis? At what point? Why?
When "breaking contact at C", what is the reaction at C?
Is cero and gives me these set of equations:
x---> Rox=Fk=17,5 N
y--> P=Roy
Moments--> -Fk*40 + P*120=0---> P=5,83N
Which is the correct answer.
Thanks voko!
