How Does Earth's Gravity Affect a Balloon?
  • Context: High School
  • Thread starter Thread starter Gh778
    Balloon Earth
The discussion revolves around the effects of Earth's gravity on a balloon and the forces acting on gases in various configurations. Participants explore concepts related to pressure, gravitational forces, and the behavior of gases in different scenarios, including theoretical setups involving masses and shapes. The scope includes conceptual reasoning and technical explanations.
  • One participant describes a balloon containing two masses and questions how forces interact, suggesting that the weight of the masses and the force from the gas must balance each other.
  • Another participant introduces a scenario with a solid object and gas, questioning how forces from gas pressure compensate for gravitational effects when holes are created in the solid.
  • A different participant asserts that according to Newton's laws, all forces must have opposing forces of equal magnitude, emphasizing that there cannot be unbalanced forces.
  • One participant proposes a simplified example involving a circle with a mass off-center, questioning how gas pressure remains consistent despite varying distances from the center.
  • Another participant states that gas pressure is not influenced by the shape of its container and that significant differences in gravitational force only occur over large distances.
  • Some participants discuss the forces acting on individual gas molecules, considering how the number of molecules affects the net force and momentum during collisions.
  • A participant reflects on their earlier misunderstanding regarding the shape of gas and its distribution around a mass, suggesting that gas maintains a consistent height regardless of the shape of the container.
Participants express differing views on how forces interact in the context of gravity and gas pressure, with no consensus reached on the specific mechanics involved. Some participants challenge each other's reasoning, indicating ongoing debate and exploration of the concepts presented.
Participants' arguments depend on various assumptions about gravitational effects, the behavior of gases, and the specific configurations discussed. Some statements involve unresolved mathematical or conceptual steps, particularly regarding the relationship between gas pressure and gravitational force.
Gh778
Imagine a balloon with nothing in it except two masses M1 and M2, like first drawing. The gas of atmosphere apply a force to move up Fgas, and the weight apply a force to move down Fm1+2. Weight of M1+M2 is equal to the force from gas (opposite direction). Now, rotate M1 and M2, like that the weight is lower because gravity is a law like 1/d². Fgas>Fm1+2. The balloon attrack Earth to up ? I though it was the diametrical atmosphere (where balloon would be) but we can put a second balloon too without rotate masses (like second drawing). So, can you explain how forces works on Earth ?
Maybe it's easier to understand my problem, watch the drawing please. A circular solid SOLID has around it GAS (it's gravity that attrack gas around it). I create a hole HOLE1 at right, this give a force F1. The force F1 come from the pressure of gas. I create another hole but now in the SOLID at left. Normally, H3 gas with gravity must compensate F1, but like a hole exist in the solid, there is less gravity, so the force F2 is lower than F1. Where is the force that compensate 100% of F1 ?
Each force has an opposing force of the same magnitude. That is just Newton. There cannot be any unbalanced force. Note that F1 is just an effective force - it is a difference between forces from air (if it would be present) to the forces in this setup (without air).
The balloon and the solid mass both pull on the string with the same force, for a total force of 0.
I really don't see the point in your 10th thread with nearly the same question.
I'm trying to explain with an easier example : take a circle with very thin wall, put in it only a mass M but not at the center. The mass of wall of the circle can be consider like 0. Put around the circle a gas. For me, the gas will be like the drawing is showing. But the law of attraction is like 1/d². At external of gas, the pressure is near 0. At the surface of the circle, the pressure is P. In this case, how is possible for the pressure of gas to be the same, because d1 different of d2 ?
The pressure of a gas is not affected by the shape of its container and differences in gravitational force are only significant for large differences in d.
Each molecule of gas receive a force Fx like drawing is showing. The number of molecules at left is more important than at right, each molecule receive a force Fx function of the local pressure, ok. Imagine at right with 2 molecules, sum of Fx forces must be lower than at left, no ? There is no effect of quantification ?
As said, all forces come in equal and opposite pairs, summing to zero.
I don't know what "quantification" means, but if you are asking if the fact that you have two simultaneous collisions matters, it does. The one molecule can gain more momentum than the individual two molecules had prior to the collision because the total momentum is conserved.
Not sure what that has to do with the previous post, though...
ok, thanks
I thinks I understood my error, in the post #4, the drawing is showing gas with a shape like egg but in fact gas (or liquid) have the same height on the black circle, it's that ? Consider circle like solar system (big d) and mass M like mass of solar system but not in the center.
Edit: I'm drawing an example, and trying to show force on gas (or liquid), the problem (for me) is the red forces, the shape for gas is or not a circle ?
  • · Replies 51 ·
  • · Replies 19 ·
  • · Replies 16 ·
