Rocket thrust, mass, speed given initial m and fuel consumption rate?
The problem involves a rocket in deep space, initially at rest, with specific parameters related to its mass, fuel consumption rate, and exhaust velocity. The questions focus on calculating the thrust, mass after fuel consumption, and final speed after a given time of engine firing.
  • Participants discuss the application of Newton's second law and the momentum integral to find thrust and changes in mass and speed. There are hints regarding the units of force and suggestions to consider formulas for variable mass systems.
Some participants have provided hints and approaches for calculating thrust and mass changes, while others express uncertainty about how to begin solving the questions. Multiple methods are being explored without a clear consensus on the best approach.
Participants are working under the constraints of the problem's parameters and are questioning the assumptions related to thrust calculation in a variable mass system.
rockchalk1312
A rocket, which is in deep space and initially at rest relative to an inertial reference frame, has a mass of 59.5E5 kg, of which 7.39E5 kg is fuel. The rocket engine is then fired for 300 s, during which fuel is consumed at the rate of 480 kg/s. The speed of the exhaust products relative to the rocket is 3.55 km/s.
(a) What is the rocket's thrust? After the 300 s firing, what are (b) the mass and (c) the speed of the rocket?
F=ma
Found mass by doing (300s)(480kg/s)=144000kg
Subtracted from 59.5E5-144000=5.81E6 kg
But I have no idea where to start on a and c. Thank you!
A hint for question a). Think about the units in Newtons equation..
Force = mass * acceleration
The units are..
= Kg * m/s^2
rearrange that a bit.
F=ma
I would use the momentum integral: ∫Fdt = Δp.
And I would use a direct formula for calculating thrust in a variable mass system: Mass rejection... :-p
Chaqu'un a son gout ...
  • · Replies 42 ·
