Gravitational Collapse of Protostars: When Does Fusion Begin?
The discussion centers around the conditions necessary for the gravitational collapse of protostars and the onset of nuclear fusion. Participants explore the relationship between gravitational potential energy, thermal energy, and the specific criteria that must be met for fusion to begin, including temperature and density considerations.
  • One participant suggests that a protostar will begin gravitational collapse if its total gravitational potential energy exceeds twice its thermal energy, proposing a specific relationship between these energies.
  • Another participant questions how much collapse is required before nuclear fusion begins, indicating that the core must reach sufficient temperature and density.
  • A participant introduces the virial theorem, discussing its implications for gravitationally bound systems and how it relates to the energies of the system.
  • There is a request for clarification on what measurements indicate that nuclear fusion is occurring, with suggestions including mass, density, and temperature.
  • One participant posits that if a protostar has initial properties such that its thermal energy is less than half its potential energy, it may collapse until equilibrium is reached, prompting a discussion on predicting the resulting star size based on these parameters.
  • Another participant notes that sub-stellar masses emit primarily in infrared and radio, with significant emissions in x-ray and gamma-ray only occurring when core temperatures reach around 11 million K.
Participants express varying views on the specific conditions required for nuclear fusion to begin, and there is no consensus on the exact measurements or thresholds that define this process. The discussion remains unresolved regarding the precise relationship between gravitational collapse and fusion initiation.
Participants mention various assumptions regarding the equilibrium of gravitational systems and the applicability of the virial theorem, but these assumptions are not fully explored or resolved within the discussion.
StephenPrivitera
A protostar will begin gravitational collapse only if the total gravitational potential energy exceeds twice the thermal energy. In other words, a gas has to be sufficiently cool and sufficiently dense to collapse. Also, as the protostar collapses about half of the gravitational PE is converted into heat, and about half is radiated into space. So suppose we have a protostar cloud with a thermal energy of T. If it is to collapse its gravitational PE should be >2T, say 3T. After some time, the protostar loses 2T in gravitational energy so that its gravitational potential energy is T. But half of the lost energy is now in heat, so the total thermal energy is now 2T. Will this protostar stop collapsing? How much must it collape before nuclear fusion begins?
Astronomy news on Phys.org
The easy answer is "until the core is hot and dense enough". Are you looking for something specific, e.g. how hot? how dense? or perhaps "it first begins to burn its deuterium, and destroy what little lithium it has, when [answer goes here]"
If the motions are not random/isotropic, the virial theorem still applies, but its form changes a bit. Similarly, since our system is made up of many objects, we can gain some insight by seeing how the orbital velocities vary with radius from the center outward.
For example, in a spiral galaxy, the dominant motion of the stars in the disk is circular rotation in the plane of the disk. The variation in the orbital velocities with radius V(r) is called the rotation curve.
Suppose you have a finite collection of point particles interacting gravitationally via good old Newtonian mechanics. And suppose that:
1. The time averages of the total kinetic energy and the total potential energy are well-defined.
2. The positions and velocities of the particles are bounded for all time.
Then we have:
<T> = -<V>/2
where <T> is the time average of the total kinetic energy, and <V> is the time average of the total potential energy.
I always found this to be a bit magical. It seems surprising at first that such a simple law could hold so generally. But in fact, it's just a special case of something called the "virial theorem", which also applies to forces other than gravity, and impacts everything from astronomy to the theory of gases.
For example, out in space, very often a bunch of particles will collapse to form a gravitationally bound system. If the system is roughly in equilibrium so the time averages of kinetic and potential energy are close to their current values, the virial theorem implies that T = -(1/2) V. we know that <T> = -<V>/2. This is a terrific thing, because it let's you find the masses of bound systems. In fact, it's really the reason we think that dark matter exists.
To be specific, suppose you measure the speeds of a bunch of visible objects in your system, and infer T. Then the virial theorem tells you V. If you find out that the potential well is deeper than what you'd get by adding up the contributions from the masses of everything you see, you know there's dark matter. People do this for spiral galaxies, elliptical galaxies, and galaxy clusters, getting strong evidence for dark matter in all cases, I guess.
Yes, I suppose this is exactly what I'm looking for. What measurements imply that nuclear fusion is occurring? Mass? density? Temperature?
Does this mean that a protostar which has the initial property T < V/2 will collapse until it reaches equilibrium at T = V/2? Suppose we know the average temperature, mass and density of a protostar. Can we predict what size star will result from the collapse by finding when T = V/2?
Temperature, and the EM spectra (same measurement). Sub-stellar masses radiate heavily in IR and radio, but you won't get x-ray, gamma ray or much UV unless the core temperatures reach ~11 million K to start fusion.
  • · Replies 21 ·
  • · Replies 19 ·
