Convergence of Sequences in [0,1]
The discussion revolves around determining the convergence of specific sequences defined on the interval [0,1]. The sequences in question are: (i) \( s_n(x) = n^2x^2(1 - \cos(\frac{1}{nx})) \) for \( x \neq 0 \) and \( s_n(0) = 0 \); (ii) \( s_n(x) = \frac{nx}{x+n} \); and (iii) \( s_n(x) = n \sin(\frac{x}{n}) \). Participants are exploring both pointwise and uniform convergence for these sequences.
  • Mixed
  • Participants discuss the pointwise and uniform convergence of the sequences, with some expressing concerns about the straightforward nature of the solutions. There is an exploration of the limits of the sequences as \( n \) approaches infinity, with specific attention to the behavior at the endpoints of the interval.
Some participants have confirmed the conclusions regarding convergence but question the reasoning behind uniform convergence. Others suggest that the differentiability of the sequences and the boundedness of their derivatives may provide insight into uniform convergence. The discussion is ongoing, with participants considering various theorems and approaches to solidify their understanding.
Participants are navigating the complexities of convergence definitions, particularly in relation to uniform convergence, and are referencing theorems related to the behavior of derivatives and compactness of the interval [0,1]. There is a focus on ensuring that the reasoning aligns with established mathematical principles.
STEMucator
Determine the convergence, both pointwise and uniform on [0,1] for the following sequences :
(i) ##s_n(x) = n^2x^2(1 - cos(\frac{1}{nx})), x≠0; s_n(0) = 0##
(ii) ##s_n(x) = \frac{nx}{x+n}##
(iii) ##s_n(x) = nsin(\frac{x}{n})##
##s_n(x) → s(x)## as ##n→∞##
(i) So for this one, I can split it into a piecewise function since ##s_n(x)## has been defined at the origin.
Taking the limit as n → ∞, I can observe two limiting functions occurring. s(x) = 0 and s(x) = 1/2.
Therefore ##s_n(x)## converges pointwise, but not uniformly on [0,1].
(ii) As n → ∞ ##s_n(x) → x = s(x)## for all x in [0,1]. Hence ##s_n(x)## converges pointwise AND uniformly on [0,1].
(iii) Exact same limit as (ii) so the same answer will follow.
Do these look okay? It seems way too straightforward so it has me a bit worried.
If anyone could confirm it would be great :). Thanks.
Yes, the conclusions about convergence are correct. But I don't see any reason why you think the convergence is uniform. A sequence of continuous functions can converge to a continuous function in a way that is not uniform. You need a better reason than just that the limit is continuous.
As in for the second and third ones? I think I see what you mean.
(ii)
##s_n(x) = 0 → 0## as ##n→∞## for ##x = 0##.
##s_n(x) = n/(n+1) → 1## as ##n→∞## for ##x = 1##.
So we get only pointwise convergence for (ii) and not uniform for all x in [0,1].
(iii)
##s_n(x) = nsin(1/n) → 1## as ##n→∞## for ##x = 1##.
So as is in (ii) we only get pointwise and not uniform for all x in the interval [0,1].
(ii)
(iii)
No, that's not what I meant at all. You were correct that they are uniformly convergent. You just didn't give a good reason (or any) reason why.
Are you implying I need to go all the way back to the epsilon definition for this?
No, I wouldn't go back that far. Don't you have any other theorems that will show that convergence is uniform? Here's a hint. In both of those cases ##s_n(x)## is differentiable and the derivative is bounded on [0,1] independent of n. Could that be useful?
Uhm I think I have this theorem I just found :
Suppose ##\{s_n'(x)\}## converges uniformly on an interval I.
If each ##s_n'(x)## is continuous and ##\{s_n(x_0)\}## converges for some ##x_0 \in I##, then ##\{s_n(x)\}##
converges uniformly on I to s(x) and :
##lim_{n→∞} s_n'(x) = s'(x)##
EDIT : So ##s_n'(x) = \frac{n^2}{(n+x)^2}##
So ##s_n'(x)## is continuous for all x in the interval.
If we choose x = 0, we see the sequence will converge to 1.
My only question is the "Suppose {s_n'(x)} converges uniformly on an interval I". Would I say : As n goes to infinity, {s_n'(x)} goes to 1. Which also happens to be the derivative of x just like the theorem is describing.
Well that just displaces the problem from showing ##s(x)## converges uniformly to showing ##s_n'(x)## converges uniformly. If you can do that then go ahead. I was thinking of something more like if ##|s'_n(x)|<M## for some constant M then if ##s_n## converges pointwise then it converges uniformly. If you can't find a theorem like that then think how you might prove it yourself. [0,1] is compact.
Wait. So you're saying that if I can bound all the positive terms of my derivative by some constant M_n, then if I have just pointwise convergence of s_n, then it converges uniformly.
##|s_n'(x)| = \frac{n^2}{(n+x)^2} ≤ \frac{n^2}{n^2} = 1 = M_n##
Since we already have shown s_n(x) is pointwise convergent, then because its derivative is bounded we can conclude that s_n(x) is uniformly convergent.
No, no subscript n. You've shown ##|s_n'(x)|## is bounded by 1. Independent of n. That's important. Showing each ##|s_n'(x)|## is bounded doesn't help. They all have to be bounded by the same constant. And they are, as you've shown. Can you say how this would show pointwise convergence of ##s_n(x)## would show ##s_n(x)## converges uniformly? Think compactness of [0,1] and epsilon. Wish I could think of the name of a theorem to refer to.
Hmm I just read about what a compact space is, but sadly I don't think I'm allowed to use any of this ( the thing about the limit points made sense ).
I still think I was correct in an earlier post in saying this ( Slightly modified now ) :
For ##x = 0, \space s_n(x) = 0 → 0## as ##n→∞##.
For ##x ≠ 0, \space s_n(x) = nx/(n+x) → x## as ##n→∞##.
So we have two values for the limiting function s(x) depending on x.
I don't think this is incorrect at all and would result in pointwise, but not uniform convergence.
Differentiating, I would get :
For x = 0. ##s_n'(x) = 0 → 0## as n→∞.
For x ≠ 0. ##s_n'(x) = \frac{n^2}{(n+x)^2} → 1## as n→∞.
So the convergence is uniform.
Since ##\{s_n(0)\}## converges, we have one point where ##\{s_n(x)\}## converges and we know that ##\{s_n'(x)\}## converges uniformly so it follows that ##\{s_n(x)\}## converges uniformly.
For ##x ≠ 0, \space s_n(x) = nx/(n+x) → 1## as ##n→∞##.
That. Is. Completely. Incorrect. The convergence is uniform. It's late and I'm running out of ways to convince you. But nx/(n+x) does not converge to 1. It converges to x. You had that part right to begin with. What changed your mind?
I had a moment of doubting myself for some reason. I added a bunch to the prior post that makes more sense than what I had before.
You just don't seem to be grappling with what uniform means. I just had a great idea. Why don't you graph s_n(x)=nx/(x+n) for some values of n, like 1, 10, 100. Does that give you some idea how you could directly prove the convergence is uniform (by epsilon ideas - not theorems)?
Going back to epsilons would probably make me feel more comfortable anyway.
##\forall ε > 0, \exists N \space | \space n>N \Rightarrow |s_n(x) - s(x)| < ε, \forall x \in [0,1]##
##|s_n(x) - s(x)| = |\frac{nx}{n+x} - x| = \frac{x^2}{n+x} ≤ \frac{1}{n+1}##
So choosing ##n > \frac{1}{ε} - 1 \Rightarrow |s_n(x) - s(x)| < ε, \forall x \in [0,1]##
Hence (ii) converges both pointwise and uniformly.
That's the idea.
Dick said:
That's the idea.
See, I understand when I go back to the epsilon definition for some reason, but the theorems he's provided for us are not sufficient for this problem I think.
(iii)
##\forall ε>0, \exists N \space | \space n>N \Rightarrow |s_n(x) - s(x)| < ε, \forall x \in [0,1]##
##|s_n(x) - s(x)| = |nsin(x/n) - x| ≤ nsin(1/n) - 1##
Having a small nitch with the arithmetic here. I can't isolate for n in terms of epsilon.
EDIT : Wait, what if :
##|s_n(x) - s(x)| = |nsin(x/n) - x| ≤ |n||sin(x/n)| + |x| ≤ n + 1##
So choosing ##n > ε -1 \Rightarrow |s_n(x) - s(x)| < ε, \forall x \in [0,1]##
(iii)
|x| isn't very small on [0,1]. That's not going to work. Look at the function x-n*sin(x/n). Is it increasing or decreasing on [0,1]?
Wouldn't it be increasing? It's derivative is 1 - cos(x/n).
##2nπ## seems to be relevant here as it is the root of the derivative.
Sure. It's increasing. It's zero at x=0 and increases to 1-n*sin(1/n) at x=1. Does that give you any ideas about how to pick an N corresponding to an epsilon?
No, I've looked at this for awhile and it doesn't seem obvious.
My question is why consider x-n*sin(x/n)? All that does is consider s(x) - sn(x) instead of the other way around.
What did I do wrong in the edit portion of my post a few posts ago? I applied the triangle inequality and then saw n+1 as an upper bound since |sin(x)| ≤ 1 and |x| = x since x is positive on [0,1] as is n.
The triangle inequality is true, but it's not useful. |x-n*sin(x/n)| gets small as n increases. |x|+|n*sin(x/n)| doesn't. It approaches 2*|x| which you are not going to be able to make less than epsilon. By showing it's increasing you've shown |x-n*sin(x/n)|<1-n*sin(1/n) for all x in [0,1]. What's the limit of the right side of that inequality?
##|x-nsin(x/n)| ≤ 1-nsin(1/n), \forall x \in [0,1]##
The limit of the right side is 0 as n goes to infinity.
So? Conclusion?
Dick said:
So? Conclusion?
Er..
I've shown ##|s(x) - s_n(x)|## is increasing and that it's bounded by ##1-nsin(1/n)## for all x in [0,1].
Wait, that means it's uniformly convergent because I've shown that if I take the limiting function s(x) and take away sn(x) I get zero as n goes off to infinity so that lim n→∞ sn(x) = s(x) for all x in [0,1].
Zondrina said:
Er..
Yes, you've shown that the difference ##|s(x) - s_n(x)|## on [0,1] is uniformly bounded by the difference at x=1. And that goes to zero. This is a good way to prove a lot of uniform convergence problems. Find the point where the difference is a maximum and then show that goes to zero.
So if checking out ##|s_n(x) - s(x)|## doesn't work, I should switch it up to ##|s(x) - s_n(x)|## and consider things at their maximum so I can get a bound. Since the difference will be bounded by 0 in this case it results in uniform convergence.
Could I ask you then, what If I got the right side limit equal to one? Does that mean one of the terms in the sequence doesn't go to zero? So the difference is bounded by 1 and so we wouldn't have uniform convergence ( At least I think ).
You are focussing on completely the wrong things here. ##|s_n(x) - s(x)|## and ##|s(x) - s_n(x)|## are EXACTLY the same thing. I just wrote x-n*sin(x/n) because it's positive. I could have written it the other way and had you show it's decreasing. Same difference. I didn't change anything by doing that. If the right side difference were approaching 1 then you wouldn't even have pointwise convergence, so there would be no reason to even ask about uniform convergence. Right? What I wanted you to carry away is what I said in the last post. If you can find a point where the difference is a maximum (which is what we did here) then answering the uniform question is easy.
Dick said:
You are focussing on completely the wrong things here. ##|s_n(x) - s(x)|## and ##|s(x) - s_n(x)|## are EXACTLY the same thing. I just wrote x-n*sin(x/n) because it's positive. I could have written the other way and had you show it's decreasing. Same difference. I didn't change anything by doing that. If the right side difference were approaching 1 then you wouldn't even have pointwise convergence, so there would be no reason to even ask about uniform convergence. Right? What I wanted you to carry away is what I said in the last post. If you can find a point where the difference is a maximum (which is what we did here) then answering the uniform question is easy.
Yes, thank you very much for the information. This clears everything up for me.
So just for completeness. I'll do ##|s_n(x) - s(x)|## which I now know is decreasing, so choosing x=1, I can bound it by ##nsin(1/n) - 1## which goes to zero as n goes to infinity so the same result would follow.
Well, yes. Just interchanging the order just interchanges increasing/decreasing and signs. It doesn't make any real difference to the problem. But ##|s_n(x) - s(x)|## is still increasing as a function of x on [0,1]. Not decreasing. It's an absolute value. I'm still not sure you are clear on what's important and what is not.
  • · Replies 17 ·
