Ball Down a Ramp Help appreciated
  • Thread starter Thread starter Nfinley1
    Ball Ramp
The discussion revolves around a physics problem involving a ball rolling down an inclined plane. The ball has a specified mass and radius, and the problem requires determining its speed after rolling a certain distance on the incline, while considering its moment of inertia and the effects of rolling without slipping.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of energy conservation principles, including kinetic and potential energy, and the relationship between linear and angular velocity. There are attempts to express the equations in terms of velocity rather than angular velocity. Some participants question the role of friction and whether it affects the energy calculations.
Participants are actively engaging with the problem, offering various interpretations and approaches. Some suggest focusing on linear kinetic energy and converting equations to simplify the problem. There is recognition of the need to clarify the role of friction, with some participants indicating that static friction is assumed and does not contribute to energy loss.
There is mention of the original poster's uncertainty regarding the frictional forces involved in the rolling motion and the potential for confusion due to edits made to the thread. The discussion also highlights the complexity introduced by the moment of inertia and the specific values provided in the problem statement.
Nfinley1
A ball of mass 2.60 kg and radius 0.120 m is released from rest on a plane inclined at an angle θ = 36.0° with respect to the horizontal. How fast is the ball moving (in m/s) after it has rolled a distance d=1.90 m? Assume that the ball rolls without slipping, and that its moment of inertia about its center of mass is 1.40×10-2 kg·m2.
Given: I = 1.40×10-2 kg·m2.
Linear Acceleration = r*ω
KE = 0.5Iω^2
PE = MGH
μ=Tanθ
Using the hypotenuse and the angle, I solved that the Height from the ground should be 1.12 m
Then, I decided to use energy equations to go about this.
ΔKE = 1/2*I*ω(final)^2 - 1/2*I*ω(initial)^2 Since it's not moving initially
ΔKE = 1/2*I*ω^2
Then Since I wanted to get linear acceleration I solved a=rω for omega and got ω=a/r
I plugged that into get an equation of ΔKE = 1/2*I*(a/r)^2. Although I've just realized my question prompts for a velocity not an acceleration, so I guess I can go back to
ΔKE = 1/2*I*ω^2
Then with ΔKE + ΔPE + ΔEThermal = 0
ΔPE = MGH final - MGH initial so 0 - MGH
1/2*I*ω^2 - MGH + ΔEThermal = 0
I know that μ should be equal to Tanθ after solving MGsinθ = μ *MGcosθ
Here's where I've kinda blanked out... I can't seem to figure out what to put for friction. As I know that exists because the ball is not slipping down the ramp
Help would be very much appreciated. Am I even headed in the correct direction?Edit: And I'm realizing now that this path leads me to an Imaginary number... so I've missed it somewhere.
You need to include linear KE. In this case, since the ball starts at rest:
ΔKE = 1/2*I*ω^2 + 1/2*m*v^2
It will be easier if you convert this equation to a function of v rather than ω.
If you continue with this energy approach, you can solve for the friction force afterwards.
If the ball was uniform, the moment of inertia for the ball would be (2/5)*m*r^2 = 0.014976 * kg * m^2, not 0.014000 * kg * m^2, but you should use the given 0.014000 * kg * m^2 value for this problem.
You don't need to worry about friction. There are no losses due to friction in rolling contact (no thermal energy produced).
I agree with all the above, except that I don't think the question asks for the friction. But I don't see any reference to an impulse, or a string, or a spring:
rcgldr said:
After the impulse, angular momentun is conserved despite the spring. You should assume the impulse is instantaneous, so the string does not expand or shrink during the application of the impulse.
Was there something else in the OP, now edited out?
Thanks for Helping
So then, now we have
1/2*Iω^2 + 1/2mv^2 - mgh + Δ Thermal Energy = 0
For change in thermal should I be using μ * N ? so Tanθ*Mgcosθ ? To get the energy from friction in this case.
This likely sounds dumb, but can you help me do this?
Or should I be solving for V with the linear kinetic energy equation?
I jumped into this course co-requisite with calculus, and while I can mostly do everything no problem, sometimes I just need somebody to call me an idiot and point me into the correct direction.
Was there something else in the OP, now edited out?[/QUOTE]
Nope... that part sort of confused me, but I looked passed it as well.
I think the friction is only necessarily because without it the object would slip rather than roll.
Unless that's not correct?
Somehow an edit I made to another post in another thread ended up in my last post of this thread, and then I couldn't get back into physics forums for a while to correct this. Sorry for the confusion.
You're supposed to assume static friction, not sliding friction and no other losses such as rolling resistance, so there is no change in thermal energy.
Stick with the energy equation you have now. You can convert 1/2*I*ω^2 into c*m*v^2, where c is some constant, in this equation:
ΔKE = 1/2*I*ω^2 + 1/2*m*v^2 = c*m*v^2 + 1/2*m*v^2 = m*g*h
so that it's a just a function of velocity and proceed from there. It would have been nicer if the ball was uniform, since in that case the radius of the ball wouldn't matter.
How would I go about defining the constant then?
rcgldr's c is just I/(2mr2) = 1.40×10-2 / (2*2.6*.122). The idea is just to make the equation a littler simpler. The important part is to replace ω by v/r so that v is the only unknown.
So then I'd use (1/4X10^2)/(2*2.6*.122) in the place of C?
I see why that's important, I'm just working on how we did it? And what do we do with it now.
Thanks for being patient with me! :)Edit: I just used what you guys said to get down to the correct answer!
I can't thank you guys enough! I learned a lot!
  • · Replies 32 ·
  • · Replies 16 ·
22K
  • · Replies 17 ·
  • · Replies 17 ·
