Is 2-Methyl-1-Propene the Correct Naming for this Molecule?
  • Thread starter Thread starter quicksilver123
    Molecule
The discussion revolves around the correct naming of a specific organic molecule, focusing on whether "2-Methyl-1-Propene" is an appropriate name or if "Methylethene" or simply "Propene" should be used instead. The scope includes conceptual clarification of nomenclature in organic chemistry.
  • Conceptual clarification, Debate/contested
  • One participant questions the necessity of the methyl prefix in the name "2-Methyl-1-Propene," suggesting that the molecule could simply be named "1-Propene" based on its three-carbon chain and double bond.
  • Another participant asserts that "Propene" is the correct name and states that the "1" is not necessary, mentioning that it is more commonly referred to as "Propylene."
  • A participant seeks clarification on whether "Methylethene" is equivalent to "Propene."
  • Another participant clarifies that "Methylethene" is not quite accurate, reiterating that the molecule is simply "Propene" and explaining that "2-Methyl-Propene" would refer to a different structure with four carbons, also known as "Isobutylene."
Participants express differing views on the necessity of the methyl prefix and the correct naming conventions, indicating that multiple competing views remain without a clear consensus.
The discussion highlights potential confusion regarding the naming conventions in organic chemistry, particularly concerning the structural implications of prefixes and the numbering of carbon chains. There are unresolved aspects regarding the definitions and distinctions between the names proposed.
quicksilver123
I've attached the image. Is the naming of this molecule correct? If so, why is the methyl prefix necessary? The three carbon chain + the double bond makes it 1-propene...
If not, would the correct name be methylethene?
Chemistry news on Phys.org
propene is the correct name the 1 is not necessary, more commonly it is known as propylene
Thanks. So methylethene=propene?
Not quite, it is just propene 3 carbons one double bond. I am not sure where the methyl propene came from. 2-Methyl propene would have four carbons it is also known as isobutylene, here is a link
http://en.wikipedia.org/wiki/Isobutylene
