Identify process in a heat engine
The discussion revolves around a heat engine problem involving a process depicted on a Volume vs. Pressure graph. The original poster presents specific values for pressure, volume, and temperature at two points, seeking to identify the nature of the process occurring between these points.
  • Participants explore the characteristics of the process, questioning whether it could be adiabatic, isothermal, isochoric, or isobaric based on the changes in pressure, volume, and temperature. Some suggest considering composite transformations to connect the points.
The discussion is ongoing, with participants sharing insights and clarifications about the nature of the process. There is a consensus that it cannot be adiabatic, but no definitive conclusion has been reached regarding its classification. Participants are actively engaging with the problem and exploring various interpretations.
Participants note that the process is represented as a straight line on the graph, which complicates its classification. There is also mention of using the ideal gas law to derive further information about work and heat, indicating a focus on the underlying principles rather than a specific solution.
physics.stu
I'm taking a practice test and I need some help with a heat engine problem.
There are three parts, the one that's giving me trouble is a-->b. The Volume v. Pressure graph shows a straight line. Pa= 5 atm Va= 5 L Ta=300K and Tb=800K are given.
So pressure is decreaseing, while volume and temperature are increasing. What type of process is this? How could I find Pb or Vb?
For an adiabatic process:
PaVa^(5/3)=PbVb^(5/3)=constant
TaVa^(2/3)=TbVb^(2/3)=constant
W=-dU(internal energy)=-(3/2)RTln(Vb/Va)
I initially thought this was adiabatic expansion but that cannot be true because of the temperature increase (as far as my limited knowledge can tell). All my calculations yield nonsense answers so I really do not think it could be adiabatic; but I may be wrong of course. Other than that I have no idea
In an adiabatic process, temperature DO change: the adiabatic process is the one in which there is no heat exchange with the outside, but temperature will change.
This said, you're right, it can't be an adiabatic process anyway, because i) if pressure decreases and volume increases, then temperature would decrease in an adiabatic process, and also ii) it is not represented with a straight line, but with a curve...
A straight line with both pressure and volume increasing sounds as no elementary transformation to me (it is neither an isochoric transf. nor an isobaric one). Also isothermal would have constant temperature so nothing to do. The only chance I see is to use a composite transformation. You could try seeing if you can connect the starting and arriving point with an isothermal and an adiabatic transformation, but the simplest way should be to use an isochoric and an isobaric.
In practice you can try to reach the final pressure with constant volume and then leave the same pressure and vary volume to reach also final volume. This is the only way I can think of anyway.
Can you use the information of b-->c to figure out the conditions at b?
I found that Pa= 10Pc so I was able to find Vc and b-->c is isovolumetric so Vc=Vb. The only question remaining is what type of process could this be?!
Thank you all for your replies. It's not isobaric/choric because both pressure and volume are changing. I'm glad you all agree that it can't be adiabatic. Maybe a-->b isn't a process that has any sort of special characteristics other than the ideal gas law. I should be able to find W and Q from other equations.
I am not aware of any special name for a transformation which is not isobaric/choric and is straight at the same time... then it has to be a general transformation for a perfect gas, and that's all
I think you're right Tia. I used W=PdV and dU=Q-W to find W and Q. Thanks for your help!
  • · Replies 67 ·
