New Reply
Heat element thermal conductor material
Share Thread
Mar18-13, 11:37 AM   #1
so i am designing a ring resistive heater-basically wrap a nichrome wire around a cylinder and heat it to 1000 degree c.
so far i have use magnesium oxide and insulator and thermal conductor and it work in theory. but when building it, i would need a special packing machine so i cant use it. i also found a cement but it has very low thermal conduct rate, so it need to be at 1600 degree before being able to heat the cylinder to 1000 degree. but the max temp for it is 1400 degree so it doest work.
so my question is are there any material that i can use to as thermal conductor and electrical insulator for the heater?
PhysOrg.com engineering news on PhysOrg.com
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
>> Faster, more precise airstrikes within reach
>> How smart technology could change public transit
New Reply
Similar discussions for: Heat element thermal conductor material
Thread Forum Replies
force on conductor carrying currentsurrounded by solid magnetic material Electrical Engineering 9
Measurement of material displacement using recorded material thermal data Materials & Chemical Engineering 3
Best Heat Absorbing Material for an Underground Heat Sink General Physics 1
Ansys- Help with thermal shell element General Engineering 0
Colder water better thermal conductor? Classical Physics 4
