Solving Problem With Forces: Calculating Force at Point C
  • Context: Undergrad
  • Thread starter Thread starter LonelyStar
    Forces
The discussion centers on calculating the force exerted at point C when two bodies are connected and subjected to an external force F at point B. Nathan describes a scenario involving a freely movable body with mass M and moment of inertia I, with the center of gravity at point A. The response clarifies that the force at point C will equal the force F, although its direction may vary based on the orientation of the bodies.
  • Understanding of basic mechanics, including forces and moments.
  • Familiarity with concepts of mass and moment of inertia.
  • Knowledge of 2D force analysis.
  • Ability to visualize the interaction between connected bodies in a rotational context.
  • Study the principles of static equilibrium in 2D systems.
  • Learn about the effects of torque and rotational dynamics on connected bodies.
  • Explore the application of free body diagrams in analyzing forces.
  • Investigate the role of constraints in mechanical systems, particularly in rotational scenarios.
Students and professionals in mechanical engineering, physics enthusiasts, and anyone involved in analyzing forces in connected systems will benefit from this discussion.
LonelyStar
Hi everbody,
I have trouble solving the following problem. I need a sollution in 2D, the 3D case does not matter.
I have a freely movable Body with mass M and Moment Of Inertia I.
The center of gravity of the body is at point A. Some Force F as pulling on the body at point B.
If the body would be sticked together with some other body at point C by a nail so that both bodies can freely rotate, what force would pull on the other body on point C?
I am sorry for my body english, it's not my native language. I hope I was able to describe the problem/question.
Thanks!
Nathan
Hi Nathan,
I think I understand your question. If the two bodies are connected at point C, then the force F that is pulling on the first body at point B will be transferred to the second body at point C, causing it to rotate. The magnitude of the force applied to the second body will be equal to the magnitude of F, but the direction may be different depending on the orientation of the two bodies.
  • · Replies 26 ·
