Mystery of the Pushed Away Black Hole
The discussion revolves around the dynamics of three black holes interacting, specifically addressing the phenomenon where one black hole is pushed away while the other two merge into a larger black hole. Participants explore the mechanics behind this interaction, including gravitational effects and angular momentum transfer.
  • One participant claims that when three black holes collide, the third one is pushed away while the other two merge, but does not provide a source for this information.
  • Another participant expresses skepticism about the claim, suggesting that black holes primarily attract each other and questioning the possibility of one being pushed away.
  • A participant introduces the idea of a slingshot effect, proposing that angular momentum transfer could allow one black hole to be "pushed" away by the other two.
  • A detailed explanation is provided regarding how three-body interactions can change orbits and momentum, using analogies with comets and planets to illustrate the gravitational dynamics at play.
  • One participant thanks another for the explanation, indicating engagement with the technical details presented.
Participants express differing views on the mechanics of black hole interactions, with some supporting the idea of a slingshot effect while others remain skeptical about the initial claim of one black hole being pushed away. The discussion does not reach a consensus on the validity of the original assertion.
Participants reference specific scenarios and analogies to explain their points, but the discussion lacks definitive sources or empirical evidence to support the claims made. The complexity of gravitational interactions among multiple black holes is acknowledged but remains unresolved.
huhjinsoo
i heard when 3 black hole crash
one which come latter will pushed away and two wil become one big black hole
here, why black hole pushed away??
im korean so i cannot write exactly
sorry
Astronomy news on Phys.org
It would be helpful if you gave the source for the information.
in 2007 we found 3 quasar crash (fact)
sounds impossible.
Maybe you are thinking of an extraordinary case where CHARGED black holes can repel?? But insofar as I know BH don't get that much charge.
gravity ATTRACTS...multiple black holes forming helps form supermassive BH.
Could it happen by a slingshot gravity assist? Two of the holes transfer their angular momentum to the third in the manner of the Voyager probes?
Yes - it is a matter of slingshot.
If heavenly bodies do not actually collide then angular momentum and energy are conserved. Heavy bodies can also radiate angular momentum and energy by gravity waves, but this is a very slow process except when they happen to move very near each other.
In two body systems, orbits are closed and the speeds are always the same at the same distance. If two black holes meet each other, they cannot get rid of their energy and momentum - they change their direction of movement but although they accelerate when they approach, they slow down again when they depart, so they end up having exact same relative speed in a different direction. Same thing with a comet approaching Sun - it comes in, it approaches Sun and accelerates, then it passes by, slows down and leaves in a different direction but with the same speed.
If two black holes already are on a bound orbit, they will keep orbiting each other at the same orbit - they cannot approach each other because they cannot get rid of their energy and angular momentum. Same thing with planets - they keep orbiting at the same distance from Sun.
But when you have three bodies, it is possible to change orbits, because they can give energy and angular momentum to each other.
Say a comet happens to pass near Jupiter when it is approaching the Sun.
If the comet passes behind Jupiter then the comet pulls back Jupiter. Jupiter slows down, comes closer to Sun - very little closer because Jupiter is big and comet is small. The comet is pulled by Jupiter and becomes faster, and after passing Sun flies away at a higher speed than before. It is not actually pushed by Jupiter, gravity always pulls, but it is pulled ahead and so it flies away. If the comet happens to pass in front of Jupiter instead, then the comet pulls Jupiter ahead - very little, Jupiter is so big that it still orbits the Sun, just a little further now - and Jupiter pulls comet back so that it starts to orbit close to Sun, or collides with Sun.
Likewise with 3 black holes. The third black hole cannot be pushed, it can only be pulled, but depending on where it passes the other two, it can be pulled ahead so that it flies away. If the third black hole is pulled ahead then the other two are pulled back, so that they either collide and become one big black hole, or else are not pulled just the exact amount to hit each other, and instead continue to orbit each other but now on a smaller orbit.
thank you so much
  • · Replies 40 ·
  • · Replies 17 ·
