Register to reply
Compression of Iron powder
by Barbados
Tags: compression, iron, powder
Share this thread:
Barbados
#1
Mar19-13, 06:33 PM
P: 2
I was just curious if it would be possible to compress fine iron powder into a solid puck without applying any heat or binding chemicals, etc. I'm guessing it would take several tonnes of force?
Particle size of powder: about 30 microns
Phys.Org News Partner Engineering news on Phys.org
Future phones to use blood and speech to monitor HIV, stress, nutrition
Neuron circuit may enable pitch perception applications
Quasi-distributed temperature sensors from draw-tower fabrication technology
SteamKing
#2
Mar20-13, 12:26 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,471
Look up 'sintering' or 'powder metallurgy'. Various metallic and ceramic products are made by compressing powdered raw material.
Barbados
#3
Mar20-13, 05:57 PM
P: 2
Thanks, I wasn't sure where to start looking. I guess my google searches were too specific.
Matcon
#4
Mar29-13, 11:25 AM
P: 23
Thirty microns is quite fine for iron powder. You would probably need a lubricant to to cold compact such a fine powder in practice. This is because fine iron has quite an affinity for water vapour from the atmosphere and the resultant surface layer of iron oxide will take quite a bit of pressure to break up this oxide layer so that cold welding between the underlying iron can occur.
Yes, you can do it, but the required pressure will be higher than you think.
In diamond setting, they compact very fine cobalt powder under very high pressure and then sinter it to get to near full density
Register to reply
Related Discussions
Thermochemistry: iron change Biology, Chemistry & Other Homework 1
Iron powder and epoxy? Materials & Chemical Engineering 3
How could i dissolve iron powder Chemistry 17
How to Separate Rust Iron (Fe2O3) into Ferum/Iron and Oxygen? Chemistry 5
Protein Powder and Beef Powder General Discussion 6
