Register to reply
Rocket Burning fuel causing change in mass
by kaikalii
Tags: burn, fuel, rocket, thrust
Share this thread:
kaikalii
#1
Mar19-13, 06:38 PM
P: 16
I made up a scenario: Let's say I have a rocket at rest in space. The rocket initially weighs 100 kg, 50 kg of which is fuel. If the fuel burns at a constant rate of 1 kg/s and produces a thrust of 100 N out the back of the rocket, what will the rocket's velocity be after it runs out of fuel?
From F=ma and V=v0+at, I derived V=Ft/m. The force is 100 N, and it would take 50 s to burn 50 kg of fuel at 1 kg/s, so it would be V=100*50/m.
My question is: What would I use for the mass, since it is changing at the fuel burns? When I assumed that it was just the average mass, 75 kg, I got the final velocity ≈ 66.7 m/s. Am I supposed to just use the average mass since the fuel is burned at a constant rate? Does rocket fuel in the real world burn at a constant rate, or exponentially? If it was exponential, could I just use calculus to find the average mass and then plug it in?
Phys.Org News Partner Physics news on Phys.org
Refocusing research into high-temperature superconductors
Neutron tomography technique reveals phase fractions of crystalline materials in 3-dimensions
Tiny magnets, huge fields: Nanoscale ferromagnetic electrodes create chemical equivalent of solid-state spin valve
berkeman
#2
Mar19-13, 06:59 PM
Mentor
berkeman's Avatar
P: 40,730
Quote Quote by kaikalii View Post
What you are asking about is known as the "Rocket Equation". Here is a tutorial from NASA:
http://exploration.grc.nasa.gov/educ...et/rktpow.html
MrAnchovy
#3
Mar19-13, 08:14 PM
P: 442
You need to use ## 50 + 50 ( 1 - \frac{t}{50} ) ##. Because the acceleration is not constant, you cannot use V=v0+at or work with an average mass though: you need to integrate a differential equation.
Register to reply
Related Discussions
Rocket thrust, mass, speed given initial m and fuel consumption rate? Introductory Physics Homework 4
Expelled rocket fuel pushing against something the rocket is attached to? Classical Physics 7
Homework help finding fraction of initial mass of rocket and fuel Introductory Physics Homework 3
Adding a mass on an oscillation causing a change in frequency Introductory Physics Homework 5
Burning salt water for fuel? General Discussion 81
