Straight line motion MCQ (Multiple choices)
The discussion revolves around a multiple-choice question related to straight line motion, specifically focusing on the acceleration of a point moving along the x-direction. The scenario describes the motion of a point starting from rest, coming to rest after a certain distance and time, and poses questions about the nature of its acceleration.
  • Exploratory, Assumption checking
  • Participants are examining the implications of the acceleration being denoted by β at any point during the motion. There is a focus on the sign change of acceleration and the limits on its magnitude based on the given conditions.
Some participants are actively questioning the assumptions made about the acceleration, while others suggest that careful consideration of the problem statement may lead to insights regarding the answer choices. There is an indication of differing interpretations of the implications of the acceleration's behavior.
Participants note the constraints of the problem, including the specific conditions under which the motion occurs and the implications of the equations of motion provided. There is also mention of the challenge in determining the correct answer based on the given data.
gaudsmack
1. 1. A point moving along the x-direction starts from rest at x=0 and comes to rest at x=1 after 1 second. Its acceleration at any point is denoted by β. Which of the following is not correct ?
a. β must change sign during the motion.
b. |β|≥4 units at some or all points during the motion
c. It is not possible to specify an upper limit for |β| from the given data
d. |β| cannot be less than 0.5 during the motion
It literally seems impossible !
2.Relevant equations:
v= u + at , s=ut + 1/2at^2 , v^2 = u^2 +2as
3.Attempt at the solution:
Just hit and trial - putting values less than, equal to or greater than 4
Let's do them in order. What do you think about the sign change?
I suggest you pay careful attention to this sentence: "Its acceleration AT ANY POINT is denoted by β." Making an immediate inference from this fact should give you the correct answer choice immediately :). Hope that helps
The answer...
the answer to the question is option D...
but the thing is that i don't know how
  • · Replies 98 ·
