| Thread Closed |
Electric Fusion? |
Share Thread | Thread Tools |
| Mar20-05, 02:19 AM | #1 |
Electric Fusion?
Why can't fusion be accomplished using high energy density electric fields?
| Mar20-05, 02:43 AM | #2 |
Mentor
I think we call the generators of high density electric fields, Lasers.
| Mar20-05, 10:14 AM | #3 |
But the laser fields vary sinusoidically with time. I am talking about a static field which sort of pushes +ions together. What are the practical difficulties in generating those high energy density fields?
| Mar20-05, 02:14 PM | #4 |
Mentor
Electric Fusion?You will notice that the highest electric field gradients that we can achieved in an accelerating structure of a particle accelerator is via using standing wave cavity of an oscillating EM field. It is prohibitively expensive, and technically unfeasable to construct a static accelerating field of the same magnitude. This is where you are going to be using up more power than you generate, so then what's the point in achieving fusion? .. and I haven't even mentioned the materials aspect yet that can withstand such high fields without serious breakdown. Zz. |
| Mar21-05, 12:48 AM | #5 |
Thank you for the reply.
What are the methods used for generating high electric fields? Do know a website which can tell me about the methods? |
| Mar21-05, 06:56 AM | #6 |
Admin
For high voltage potential differences, the good old Van der Graaff machine comes to mind - http://members.aol.com/_ht_a/lyonelb/sis.html
http://hyperphysics.phy-astr.gsu.edu...vandeg.html#c1 http://hyperphysics.phy-astr.gsu.edu...accel3.html#c2 Then there is the Cockcroft-Walton accelerator. I am not sure of the specific voltage per stage. I have seen numbers in the 100's kV range. |
| Mar21-05, 07:38 AM | #7 |
Are static electric forces stronger that magnetic ?
How much voltage are we talking about ? |
| Mar21-05, 08:47 AM | #8 |
Recognitions:
[tex]F = kq^2/r^2 = 9e9*(1.602e-19)^2/e-30 = 230N[/tex] per proton. A proton's cross sectional area is on the order of e-30 m. or less, so you would need a force/area of 2.3e32 N/m^2. Try to achieve that! The real reason you could never achieve that kind of force with an electro-static field is because coulomb force has to come from electrons or protons. If you think about it, their static field can't produce a force/unit area greater than the force that you are trying to overcome. AM |
| Mar21-05, 09:36 AM | #9 |
Recognitions:
Actually electric fields and magnetic fields are the same thing. Magnetic fields are caused by the motion of electic fields. Relativistic effects make the electric field look like a magnetic field. Although it is frequently taught that Einstein developed Relativity to explain the null result of the Michaelson-Morley experiment; Einstein's true motivation was due to Maxwell's equations of electrodynamics. The influence of the M-M experiment was rather indirect. "The influence of the crucial Michelson-Morley experiment on my own efforts has been rather indirect. I learned of it through H.A. Lorentz's decisive investigations of the electrodynamics of moving bodies (1895) with which I was acquainted before developing the special theory of relativity . . . What led me more or less directly to the special theory of relativity was the conviction that the electromotive force acting on a body moving in a magnetic field was nothing else than an electric field." -Albert Einstein Dr. Gregory Greenman Physicist |
| Mar24-05, 06:36 AM | #10 |
| Mar28-05, 10:02 AM | #11 |
Magnetic (we've already gotten past the EMF = movement of E fields part) confinement is most difficult because the various reactor designs all have faults that lead to less than optimal Lawson criterion.
Magnetic confinement fusion is like trying to squeeze jello with a cargo net. You need a very dense, indefinitely sustainable confinement field arrangement that can maintain the plasma at the necessary temperatures. Right now the biggest barriers in this regard are costs of materials to build large enough reactors, thermal and shielding limites of materials, and associated changes in magnetic properties. It's a challenge that requires more resources (time, money, and man/brain-power) than are currently allotted (worldwide) to accomplish this any time in the forseeable future. |
| Mar29-05, 05:15 AM | #12 |
| Mar29-05, 09:23 AM | #14 |
Recognitions:
Exactly. When magnetic forces are used to confine the plasma - it's called magnetic confinement fusion. However, the link above describes the process of "inertial confinement fusion". One uses lasers, like at LLNL; to implode a small target of fusion fuel. There's no attempt to contain the plasma - the plasma is contained due to its own inertia for the brief period of time needed for the reactions to take place. The latest fusion laser at LLNL is the NIF - the National Ignition Facility. This laser, as big as a sports arena; should be powerful enough to actually achieve fusion ignition: http://www.llnl.gov/str/September03/Moses.html One can also do what LLNL does with lasers with big pulsed power machines like at Sandia. The "Z Pinch" machine in action: http://zpinch.sandia.gov/Z/Images/z.jpg This machine puts very large currents into a series of wires. The current and the magnetic field interact and implode the wire assembly and compress a fusion target, similar to the way the LLNL lasers do. Dr. Gregory Greenman Physicist |
| Mar29-05, 01:08 PM | #15 |
| Mar30-05, 08:34 AM | #16 |
Other methods of achieving fusion are inertial confinement (lasers), and inertial electrostatic, which is sort of hard to describe, but the device is small and makes an excellent table-top neutron generator. Unfortunately, we can't yet get a power gain out of any designs. The Pons/Fleischmann experiements for cold fusion back in the late 80s were just bad science. My fusion prof back in school became visibly angered if you ever brought them up in class. The most promising idea for room-temperature devices for achieving fusion had something to do with imploding bubbles in acetone, but I don't know what progress (if any) was ever made on that one. |
| Mar30-05, 09:33 AM | #17 |
Recognitions:
I don't think we can say that "Fusion CAN be achieved with magnetic confinement.." quite yet. We do not as yet have a proof of principle for fusion ignition via magnetic confinement. As we have built larger and larger machines - like the family of tokamaks at the Princeton Plasma Physics Lab; PLT [ Princeton Large Torus ] and TFTR [ Tokamak Fusion Test Reactor ]; to name the latest two in the series - we've seen more and more varied plasma instabilities that have circumvented our quest for magnetic fusion. Hopefully, the latest machine - the ITER - will be more successful. The progress in inertial fusion has been more sustained. Inertial fusion ignition has been accomplished in the aforemention hydrogen bombs - but also the progress has been more sustained in the laser fusion arena. The main problem facing laser fusion was to be able to drive a target that was big enough - so that it could capture the product alpha particles and achieve ignition. Calculations indicate that the new LLNL laser - the NIF [ National Ignition Facility ] will be large enough and powerful enough to achieve ignition [ hence the name ]. Dr. Gregory Greenman Physicist |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electric Fusion?
| Fusion and atomic states | General Physics | 6 | ||
| Is 40,000 joules of energy enough for Nuclear fusion? | General Physics | 3 | ||
| hot fusion | General Physics | 0 | ||
| Sun Fusion | Introductory Physics Homework | 3 | ||
| fusion | High Energy, Nuclear, Particle Physics | 5 | ||
