How to relate the radiation pressure to the internal energy?
The discussion revolves around the relationship between radiation pressure and internal energy, specifically exploring how to derive the formula P = u/3 for electromagnetic radiation in equilibrium. Participants examine various theoretical approaches, including kinetic theory and classical field theory.
  • One participant inquires about the derivation of the formula P = u/3 and references the Stefan-Boltzmann law.
  • Another participant explains that for equilibrium radiation, the Maxwell pressure is one third of the average Poynting energy density, suggesting a reference to Landau Lifgarbagez's work.
  • A kinetic theory approach is presented, where pressure is derived from the behavior of gas molecules, leading to a similar conclusion for photons by replacing mass with energy density.
  • Clarification is provided regarding the factor of 1/3 in the context of momentum change during collisions, with a participant confirming the arithmetic involved.
  • A participant expresses confusion about the time for momentum change and requests further guidance on the derivation.
  • Another participant critiques a standard derivation used in education, suggesting a preference for a different approach based on historical texts.
  • Questions arise about the integration method used in the derivation, with participants discussing the relevance of volume and area in the context of molecular collisions.
Participants present multiple competing views and approaches to the derivation of the relationship between radiation pressure and internal energy. There is no consensus on a single method or explanation, and some participants express differing opinions on the validity of certain derivations.
Some participants note limitations in the standard derivation methods, including assumptions about container shape and the treatment of molecular interactions. There are unresolved questions regarding the time intervals involved in momentum changes and the specifics of integration techniques.
Outrageous
Science news on Phys.org
This relation holds for the EM radiation in equilibrium. It turns out that the Maxwell equations are such that for equilibrium radiation the Maxwell pressure is one third of the average Poynting energy density. For the derivation, look for example into the sections 34,35 of Landau Lifgarbagez "The Classical Theory of Fields", 4nd edition.
See how you like this kinetic theory approach...
For N molecules of mass m in a container of volume V the pressure p is [tex]p = \frac{1}{3}\frac{N}{V} m \left\langle c^2 \right\rangle.[/tex]
For a gas whose particles all travel at the same speed, we have simply
[tex]p = \frac{1}{3}\frac{N}{V} m c^2 .[/tex]
[itex]\frac{1}{6}\frac{N}{V} m c[/itex] represents the total molecular momentum in a direction normal to and towards a given area of wall, per unit volume of container. This is standard kinetic theory. [itex]\frac{N}{V}[/itex] is the number of molecules per unit volume.
Now, for photons, we can replace [itex]\frac{1}{6}\frac{N}{V} m c[/itex] by [itex]\frac{1}{6}\frac{u}{c}[/itex] in which u is the photon energy per unit volume. This because the momentum of an individual photon is [itex]\frac{h}{\lambda}=\frac{hf}{c}[/itex] = photon's energy /c.
Hence we finish up with [itex]p = \frac{1}{3}u.[/itex] The factor is [itex]\frac{1}{3}[/itex] rather than [itex]\frac{1}{6}[/itex], just as for molecular gases, because the force on the wall is due to the change in momentum of particles when they collide, and the total normal momentum of reflected particles is equal and opposite to that of incident particles.
Thank you
Do you mean that 1/6 + 1/6 =1/3.
Indeed I do. Or, better still: 1/6 - (-1/6) = 1/3.
This is the derivation I found. But I don't understand how can the time for the change of momentum is so large? Why is not the moment when it changes momentum but the time between collision.
But I think you may have better derivation , can you please guide?
Thank you
I'll deal just with molecular gases, not photons. The molecular gas treatment can be adapted to photons as explained earlier.
1. Dividing by the time for a collision to take place would give you the mean force exerted by a molecule on the wall when it's colliding. But that's not what you want. You need the mean force on the wall all the time, whether or not a molecule is in the process of colliding.
2. I'm not fond of the derivation you give, though it was the standard one given to A-Level students in the UK, in the days when exam boards still required a derivation to be known. Students, quite reasonably, disliked the restriction of the cuboidal container, and the notion of a molecule bouncing back and forth between opposite walls, unimpeded by other molecules.
The derivation in the thumbnails below is, in my opinion, far superior. It is my version of a derivation I first met in a very old book, The Kinetic Theory of Gases by Sir James Jeans. Note that, in the thumbnails, I'm using u to mean x-wise velocity component, not energy per unit volume!
If you're happy with a bit of integration, there's another version of the Jeans argument which you might prefer. It deals differently with the 'grouping' of molecules by velocity.
Really thank you. One thing to ask why do the total momentum need to times prism volume / V ?
Can you please upload the integration one? Thank you.
(prism volume)/(container volume) is the fraction of the Nu,v,w molecules (with the relevant velocities) in the whole container which are in the prism, and therefore which will hit area A of the wall in time [itex]\Delta t .[/itex]
Yes, I'll post the integration method soon.
As promised...
Thank you for uploading .
We integral the theta from 0 to pi/2 because we consider that strip volume can be a semi sphere?
Exactly so, except that it's area, not volume.
Yup, should be area. Really thank you.
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 20 ·
33K
  • · Replies 29 ·
