Requirements for Water Spout pressure trick, at 100 scale?
The discussion centers on the requirements for achieving consistent water flow from a large-diameter water spout, specifically one that is 5 feet wide. The key conclusion is that the flow becomes intermittent if the spout diameter exceeds a fraction of an inch due to air bubbles disrupting the flow. The pressure differential necessary for continuous flow is determined by the formula: pressure(psi) inside must be less than outside pressure by the product of water density (in lbs per cubic inch) and the depth of water (in inches) above the center of the spigot.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure differentials in liquids
  • Familiarity with water density calculations
  • Basic grasp of spout design and flow mechanics
  • Research fluid dynamics and pressure differentials in liquids
  • Explore calculations for water density and its impact on flow
  • Learn about spout design considerations for large diameters
  • Investigate methods to maintain consistent flow in large water dispensers
Engineers, fluid dynamics researchers, product designers, and anyone involved in the design of large-scale water dispensing systems.
mgmguy
Hello this is my first post, so if I am supposed to move this to another forum section please advise I would be happy to
http://foryourwater.com/mm5/graphics/00000001/3_gallon_dispensing_water_bottle_lg.jpg
As for my question, I am referencing the example of a water dispenser above, after a certain amount of flow, the water simply won't come out anymore. I assume this is because the amount of pressure/vacuum within the bottle is higher than the outside environment on the other side of the spout. Only until the lid is opened, shall the water then flow again. If someone is to look closely, they will see a level of water being suspended in mid air due to this, inside the spout.
I am curious of the requirements to do this in something let's say 5 feet wide in diameter. Is there a way to calculate the pressure required? I am wondering the pressure needed to accomplish this and if its possible
thanks
Matt
The limiting element is the size of the spout. If it is wider than a fraction of an inch, the flow will become intermittent, as air bubbles go up the spout.
I think it's:
...pressure(psi) inside LESS than pressure outside by this amount:
...[density of water (in lbs per cubic inch)] X [depth of water(in inches) inside above center of spigot]
can you explain why?
  • · Replies 20 ·
12K
  • · Replies 32 ·
13K
  • · Replies 56 ·
