Recommendation for good book for IC Engine design
The discussion revolves around recommendations for books on the design of internal combustion (IC) engines, focusing on various components such as camshafts, crankshafts, timing belts, and pumps. Participants seek resources that cover both practical design aspects and theoretical foundations.
  • Homework-related
  • One participant requests a comprehensive book on IC engine design that includes various components and their interrelations.
  • Another participant seeks clarification on the abbreviation "IC," suggesting it likely stands for "internal combustion."
  • A participant expresses interest in resources that cover the design of specific components like camshafts, valve timing, and crankshafts, indicating a desire for detailed technical information.
  • One participant shares a link to a PDF that covers many of the requested topics, suggesting it may be a useful resource.
  • A later reply asks for recommendations on analytical design resources, emphasizing the importance of understanding how different mechanisms in the engine work together.
Participants generally agree on the need for resources related to IC engine design, but there is no consensus on specific book recommendations or the best starting point for design.
Participants express varying levels of familiarity with the subject, and there are indications of differing expectations regarding the depth and focus of the resources sought.
sci-phy
Hey Everyone,
I'm a mechanical engineering student and I was wondering if there was any good book regarding IC Engine design; which includes timing belt design, camshaft, crankshaft, rocker-arm, pump design etc.. a whole in one package that design engineers use for designing ic engines.
Thanks in advance :smile:
What does "IC" stand for? I might guess "internal combustion" but would rather you say what you mean, please. After that, folks may feel more confident in understanding your meaning and would be able to offer more meaningful comments.
Bobbywhy
Thanks for your advice! newbie here. Will keep that in mind :smile:
I was just looking for a book or any other reference to understand design of Internal Combustion engines. Most books talk about air std cycles, radiators, carburetors and their thermodynamics etc.. I would like to know about design of camshaft, valve timing, crankshaft, timing belts ( material, gear ratios), oil and water pump design, rocker arm mechanism and design etc... Can you suggest some books for the same?
Thanks for the clarification. Using the Google search terms “design of camshaft, valve timing, crankshaft, timing belts ( material, gear ratios), oil and water pump design, rocker arm mechanism and design” I found this 62 page pdf file:
http://www.google.com/url?sa=t&rct=...AV-df_4ogiVCE3fGA&sig2=ydnmSPFnWdvggqEsM2X8nw
that goes into a lot of the details you asked about. There were several more to choose from. Good luck.
Bobbywhy
Wow! Thanks! It was really helpful :smile:
If it wouldn't be much trouble, can u also please suggest any good books/ref for the analytical design part? Like theoretical design of cams based on valve timing diagram, timing belts, crankshaft and it's balancing, design of rocker arms and it's springs, design of flywheels etc.. I'm really interested to know how the entire engine works as one giant unit of mechanisms since each and every mechanism depends on the other. So, where do you start designing from?
Thanks again :smile:
