Free Vibration of Spring system with two DOF
The discussion focuses on the free vibration of a spring system with two degrees of freedom (DOF). It establishes that for a non-trivial solution of the simultaneous equations governing the system, the determinant of the coefficients of the variables \(X_1\) and \(X_2\) must equal zero. This condition indicates that the system can vibrate at specific frequencies, denoted by \(\omega\), where the determinant becomes zero. If the determinant is non-zero, the only solution is trivial, \(x_1 = x_2 = 0\), which lacks physical significance.
  • Understanding of linear algebra, specifically determinants and matrices
  • Familiarity with the concepts of degrees of freedom (DOF) in mechanical systems
  • Knowledge of free vibration analysis in mechanical engineering
  • Basic understanding of harmonic motion and oscillatory systems
  • Study the derivation of the characteristic equation for two DOF systems
  • Learn about eigenvalues and eigenvectors in the context of vibration analysis
  • Explore the application of the Rayleigh quotient in determining natural frequencies
  • Investigate the effects of damping on free vibration in multi-degree-of-freedom systems
Mechanical engineers, students studying dynamics, and researchers interested in vibration analysis of multi-degree-of-freedom systems will benefit from this discussion.
nerak99
In some questions I am doing, you set of a pair of simultaneous equations and in the notes we have that . For a non trivial solution of X1 and X2,the determinant of
coefficients of X1 and X2 must be zero.
An equation might typically look like this [itex](m \omega^2 +k_1)x_1 +k_2 x_2=0[/itex]
Why must the determinant be zero? When solving SEs in general using matrices, the determinant must be non-zero?
For free vibtration, there are no external forces appplied to the system, so the right hand sides of the equations are 0.
If the determinant is non-zero, the only solution is ##x_1 = x_2 = 0## which is not very interesting!
The determinant is only zero for "special" values of ##\omega##, and these are the frequencies at which the system can vibrate.
Thanks for that. I still don't understand "why" but that is v helpfule.
  • · Replies 21 ·
  • · Replies 22 ·
