Register to reply
If you could see gravity what do you think it would it look like?
by jt3213
Tags: gravity
Share this thread:
jt3213
#1
Mar22-13, 11:10 PM
P: 3
If you could see gravity what do you think it would it look like? The trampoline, or fabric example doesn't seem right to me. I guess I've always imagined gravity as a 'fluid' for lack of a better term. I just imagine the gravitational field expands in all directions creating a sphere of gravity around the object. What are your opinions on this? Does my idea sound like a correct visualization?
Phys.Org News Partner Astronomy news on Phys.org
Spectacular supernova's mysteries revealed
Supernova seen in two lights
A chemical signature of first-generation very-massive stars
Bobbywhy
#2
Mar22-13, 11:44 PM
PF Gold
P: 1,899
jt3213,
Your visualization "the gravitational field expands in all directions creating a sphere of gravity around the object." is exactly correct.
Bobbywhy
jt3213
#3
Mar23-13, 12:15 AM
P: 3
Thanks
TheTechNoir
#4
Mar23-13, 03:51 AM
P: 110
What bobby said is correcting. Just adding in, the point of visualizing it as a fabric or trampoline isn't that it is supposed to look like that. That is more of a cross-section view showing one half of the gravitational field/influence the object has on it. It's more difficult and confusing for a viewer if they try to draw a full sphere of grid-lines encircling a solid object to illustrate how that object warps those lines due to the overlap.
There is also the option with a cross-section then to use instead of grid lines a solid object such as, like you said a trampoline. but if you tried to have the same influence on all angles of an object using a solid fabric you wouldn't be able to see the object inside it for the visualization.
surajt88
#5
Mar25-13, 01:09 PM
P: 76
I'll try in helping you visualise gravity. :)
First, the basics. Gravity is a weak force, but has a long range. An electron, being such a small particle, still can exert its gravitational influence (albeit very weak) to the very end of the observable universe (if we had a sensitive enough instrument to measure it, we can!).
Now to the visualizing part. I assume you ask this question from the perspective of an observer on earth. From this perspective, "gravity" "reduces in its intensity" as we go skywards. Since you talk about "fluids", I'll try to help you visualise this on the basis that, the stronger the gravity is, the "darker" it is to see around. If you had the sense to visualize gravity in this sense, what you would see would be similar to what a fish would see in a murky pond. the deeper you are, the murkier and darker it gets. So on the surface of the earth, you wouldn't be able to see a thing, but, as you go higher, things start clearing up and when you reach "space", you start seeing things. In this case, the level of "darkness" corresponds to the strength of gravity.
What it means actually is that, from the perspective of a person on the surface of the earth, gravity reduces gradually from the surface as you move skywards.
ImaLooser
#6
Apr3-13, 03:11 AM
P: 570
Quote Quote by jt3213 View Post
For Newtonian 1/r^2 gravity it will work just fine. With the weird effects of general relativity like gravity waves you won't have much luck. I don't know any simple model that works for that.
Register to reply
Related Discussions
Gravity: Point where Earth's Gravity and the Moon's cancel each other out? Advanced Physics Homework 21
How to calculate mass of fuel needed to escape Earth gravity vs. Mars gravity Astronomy & Astrophysics 2
Does gravity affect gravity the way gravity affects time? General Physics 12
[help]how to obtain gravity eqution from gravity field Action S? Advanced Physics Homework 2
Gravity has to have an effect on time,when gravity can curve space ,it Astronomy & Astrophysics 8
