Register to reply
IPA and EtOH Spearation via Distilation Column
by ChEtobe14
Tags: column, distilation, etoh, spearation
Share this thread:
ChEtobe14
#1
Mar23-13, 03:12 PM
P: 10
Hi,
So I am wondering if anyone would have any ideas on to how to maximize the most of my data collection efforts into characterizing a distillation column that we are using in my senior design course to separate a mixture of IPA and EtOH. The column contains sieve trays, with 5 of them residing in the enriching section and 10 of them in stripping section. I will be operating this column at total reflux. We are asked to find a design based on the experimental data obtained to design a system that will recover 90% of the EtOH with a purity level no less than 85%.
I spoke to my professor regarding what data I need to collect, however I am not sure as to how to go about doing this. He said I need to use the HTU-NTU method and find the mass transfer coefficients. Problem is, I never learned this in my separations course. Another problem is, I cannot access the trays to attempt to analyze the compositions at each stage. I only have access to the product exiting from the top of the column.
I have only two manipulated variables the condenser water flow rate and the power input into the reboiler. Here is what I am planning on doing:
1. Start analyzing, by gas chromatography, different mixtures of IPA and EtOH. Generate a calibration curve base don that. Calibrate the water flow meter since it is unit-less and relate it to the amount of water exiting the condenser over an interval of 2 minutes. 5 different trials will be performed.
2. I am stuck :/ . I am not sure how to proceed from here to gather the required data needed for full characterization.
If anyone could be so kind as to point me in the right direction, I would really really appreciate it!
Thanks!
Phys.Org News Partner Engineering news on Phys.org
Researchers discover cool-burning flames in space, could lead to better engines on earth (w/ Video)
Professors object to FAA restrictions on drone use
UConn makes 3-D copies of antique instrument parts
Register to reply
Related Discussions
Aftermath of polymerization of EtOH Chemistry 5
Column Help? Engineering, Comp Sci, & Technology Homework 10
Prove the column space of AB is contained in the column space of matrix A Linear & Abstract Algebra 3
Why is 70% etoh and 30% h20 more effective than 100% of either? in microbio terms Biology 10
Column Introductory Physics Homework 2
