Solving the Relativistic Dilemma: Object A Overtaking Object B
  • Thread starter Thread starter Pengwuino
    Relativistic
The discussion revolves around a relativistic problem involving two objects, A and B, moving in the positive X direction at different speeds (0.900c and 0.800c, respectively) as observed from Earth. The original poster is trying to determine the speed at which object A overtakes object B from A's perspective, questioning the apparent discrepancy in expected results.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need for Lorentz transformations instead of Galilean ones, with some attempting calculations to find the relative speed of A as observed by A. Questions arise regarding the correct application of reference frames and the implications of relativistic speeds.
There are various attempts to clarify the problem, with some participants providing guidance on keeping track of reference frames and the measurements involved. Multiple interpretations of the problem are being explored, but no consensus has been reached on the correct approach or solution.
Participants emphasize the importance of understanding the measurements from different reference frames and the implications of relativistic effects, indicating that assumptions about simultaneity and relative motion are under scrutiny.
Pengwuino
Ok i think the book is trying to noobify me by tricking me... ok here's the problem.
Ok so Earth is the origin
Object A moves in the positive X direction at 0.900c measured from the earth
Object B moves in the positive X direction at 0.800c measured from the earth
Object B is further along on the X axis as object A so B will soon overtake object B.
Observers on the Earth witness A overtake B at a relativistic speed of 0.100c
With what speed is A overtaking B if observed by A?
Shouldnt it be the same, 0.100c?
NO! You are not doing a Gallilean transform of coordinates. This is a Lorentzian transform. The Earth frame is the rest frame. You need to think of what velocity observer A is seeing B going at as well as what observer B is seeng A go at. Just try to keep track of your reference frames so you don't get lost.
So is it .36c?
I used u'x = (ux - v)/(1-(ux * v)/c^2)
Ok that's not right either... how in the world :D
Earth sees A moving away at 0.8c so A sees Earth moving away at 0.8c. If B is movi g away from Earth at speed v (relative to A) then its speed, relative to Earth is
(0.8c+ v)/(1+ 0.8v/c2)= 0.9c. Solve for v.
How this: Let us assume that all three observers will start measuring their times and distances simultaniously starting at an abritrary time and place. So, from the Earth observers pointof view we have:
at [tex]T_{0}=0[/tex], just to make the math easier, spaceship A is at point [tex]X_{A0}[/tex] and spaceship B is at [tex]X_{B0}[/tex], and when B passes A we'll have [tex]T_{f}[/tex] where A is at [tex]X_{Af}[/tex] and B is at [tex]X_{Bf}[/tex]. Let us go ahead and say that [tex]X_{Af}=X_{Bf}[/tex] to make things simpler.
Now from the Earth observers point of view we already know that [tex]\frac {X_{Bf}-X_{B0}}{T_{f}}- \frac {X_{Af}-X_{A0}}{T_{f}} = 0.1c[/tex]
The question you need to ask yourself is what from the point of view of ship A what [tex]X_{Af}-X_{A0}[/tex] will be measured and what [tex]T_{f}[/tex] will be measuered as well as what [tex]X_{Bf}-X_{B0}[/tex]. The Lorentz factor for ship A will yeild the correct result. Now the same goes for observer B as well except the Lorentz factor will be different. This may seem like a long way of doing this but it is imperitive that you properly peg down what is being measured in what frame as well as the basis for what is being measured. Once you see who is measuring what you'll be able to see the easier way of doing so I hope this helps a little and at best you'll have to do a little algebraic manipulation. I can't overemphasize the idea keeping track of who is measuring what relative to the rest frame, once you get this down you'll find it easier when you start looking into GR. Good Luck and I hope this helps a little!
HallsofIvy,
Are you saying that Euclid was a voyer with your signature?:smile:
"HallsofIvy,
Are you saying that Euclid was a voyer with your signature?"
No, that's the first line of a well known poem by Edna St. Vincent Millay:
Euclid alone has looked on Beauty bare.
Let all who prate of Beauty hold their peace,
And lay them prone upon the Earth and cease
To ponder on themselves, the while they stare
At nothing, intricately drawn nowhere
In shapes of shifting lineage; let geese
Gabble and hiss, but heroes seek release
From dusty bondage into luminous air.
O blinding hour, O holy, terrible day,
When first the shaft into his vision shone
Of light anatomized! Euclid alone
Has looked on Beauty bare. Fortunate they
Who, though once only and then but far away,
Have heard her massive sandal set on stone.
I know, I was just having a little fun! :biggrin: Thanks for posting it!
Though I have to admit that the line alone can give one a nefarious impression of Euclid! :smile:
  • · Replies 44 ·
  • · Replies 18 ·
