JoakimvE
- 8
I am currently doing a lab trying to calculate internal resitance of a battery. Do I use the formula V=IR?
The discussion revolves around calculating the internal resistance of a battery in a lab setting, with participants exploring the relevant formulas and experimental setups.
The conversation includes various attempts to clarify the experimental approach and the relationship between voltage, current, and resistance. Some participants provide insights into the effects of measurement devices, while others express uncertainty about their experimental values and the variability of resistance.
Participants note the importance of accurately measuring voltage and current, and there is mention of needing to account for the effects of different types of meters used in the experiment. Additionally, there is a concern about how to quantify the resistance added during the experiment.
JoakimvE said:you mean to say, that an ammeter or voltmeter would come to effect my results?![]()
This depends on the meters you are using. If you are using a modern digital meter, then then I doubt that you will be able to detect their presence. If you are using an old fashioned analog meter with a D'Arsonal/needle movement, then yes, they will have a measurable effect.JoakimvE said:you mean to say, that an ammeter or voltmeter would come to effect my results?![]()
JoakimvE said:anyhow, i guess the main problem is how much i varied the resistance by. i just varied the electric field (E)... I am guessing i can't calculate the resistance i added.
