How Does Lung Capacity Affect Body Density?
  • Thread starter Thread starter Kcoats
    Density
The discussion centers on calculating the density of a man when his lungs are full, given his mass of 58.9 kg in air and an apparent mass of 1.0 kg when submerged in water. The correct density when his lungs are full is established as 985 kg/m³. Participants clarify that the man's volume, which displaces 57.9 kg of water, is 57.9 liters, and when accounting for the lung capacity of 1.9 liters, the final density calculation confirms the correct answer of 985 kg/m³.
  • Understanding of basic physics concepts, particularly buoyancy and density
  • Familiarity with unit conversions, specifically liters to cubic meters
  • Knowledge of density calculations and the formula density = mass/volume
  • Ability to perform arithmetic operations with scientific notation
  • Study the principles of buoyancy and Archimedes' principle
  • Learn about density calculations in fluid mechanics
  • Explore unit conversion techniques between metric units
  • Investigate the effects of lung capacity on overall body density
Students in physics, educators teaching density and buoyancy concepts, and professionals in health sciences examining body composition and density metrics.
Kcoats
In a measurement of a man's density he is found to have a mass of 58.9 kg in air and an apparent mass of 1.0 kg when completely submereged in water with his lungs empty. If his lung capacity is 1.9 liters, what is his density when his lungs are full?
Correct answer: 985 kg/m^3
Okay, here is how I have been working it. Where am I going wrong?
1.9L(1000cm^3/1L)(1m^3/100cm^3)=1.9E1
58.9 kg-1.0 kg=57.9 kg/10^3 kg/m^3=5.79E-2 kg/m^3 +1.9E1 m^3=1.90E1 m^3
58.9 kg/1.90E1 m^3=3.105E-1 kg/m^3
You have to work out the volume of the man. Since his volume displaces 57.9 kg of water, his volume is 57.9 litres. If he increases that volume by 1.9 litres (to 59.8 L) but does not add weight, his density is:
58.9kg/59.8 L = .985 kg/L or 985 kg/m^3
AM
Based on the given information, it seems like your calculations are correct. However, the final answer should be in kg/m^3 and not just kg/m^3. When converted, your answer of 3.105E-1 kg/m^3 is equivalent to 310.5 kg/m^3 which is not the correct answer. To get the correct answer, you need to divide the mass of 58.9 kg by the volume of 1.9 liters (or 0.0019 m^3) to get a density of 31000 kg/m^3. This is the density when his lungs are completely full. However, since we are looking for the density when his lungs are full, we need to subtract the density of air (1.2 kg/m^3) from the density of the man when his lungs are full to get the final answer of 31000 kg/m^3 - 1.2 kg/m^3 = 985 kg/m^3. This is the density of the man when his lungs are full. I hope this helps!
  • · Replies 17 ·
