Hooke's Law and Force in a Slingshot
The discussion revolves around a problem involving Hooke's Law and the dynamics of a slingshot. The scenario includes a rock being launched from a slingshot, with participants analyzing the force exerted by the rubber band and its implications on the motion of the rock.
  • Participants explore the direction of the rubber band's stretch, the applicability of Hooke's Law, and the calculation of the spring constant. There are also discussions on energy conservation principles related to the system.
Some participants have provided insights into the relationship between force and displacement, while others have suggested using energy conservation to approach the problem. There is acknowledgment of errors in calculations and clarifications regarding the formulas used.
Participants note the importance of unit conversion, specifically converting mass from grams to kilograms, which is relevant for accurate calculations in the context of the problem.
mcnealymt
A 46g rock is placed in a slingshot and the rubber band is stretched. The force of the rubber band on the rock is shown by the graph in the figure(Figure 1) .
http://session.masteringphysics.com/problemAsset/1073689/4/10.P37.jpg
a)Is the rubber band stretched to the right or to the left?
b)Does this rubber band obey Hooke's law?
c)What is the rubber band’s spring constant k?
d)The rubber band is stretched 29cm and then released. What is the speed of the rock?
Fsp= -kΔx
a) Left because the displacement is negative and therefore the Fsp must be positive?
b) Yes, it obeys Hooke's Law because as the displacement increases, the amount of force does?
c) Isn't it just the slope of the given graph?
d) Honestly not sure where to begin.
a) and b) are correct but b) can be amended as " the force is proportional to the displacement and in opposition to it and hence obeys the law".
For c) yes it is the slope.
For d) are you aware of the expression for energy stored in the band as a function of the stretch(x)? If yes, try conservation of energy. If no, try deriving the expression using
Energy stored=∫F.dx for the band and then use conservation of energy.
Alright, thank you. It turns out I forgot to convert the mass to kg.
This is what I got:
Spring Potential Energy= Kinetic Energy
Us (initial)=KE (Final)
.5kx^2= .5mv^2
V= Square root of ( K*X/m)
k= spring constant
X= change in displacement
m= mass of the rock
You mean square root of Square root of ( K*(X^2)/m) right? That was unintentional on your part I guess.
Anyway, Enjoy Physics.:smile:
Lol, fail on my part... thanks Sunil Simha.
  • · Replies 35 ·
  • · Replies 17 ·
25K
  • · Replies 17 ·
