| Thread Closed |
Aharonov Bohm effect |
Share Thread | Thread Tools |
| Mar22-05, 07:53 PM | #1 |
When we derive the phase difference in the classical experiment of the solenoid as shown below
http://www.public.asu.edu/~ziyads/Aharonovbohm.pdf Now what if we change the path from the sorce to screen so it follows a rectangular path like this http://www.public.asu.edu/~ziyads/rect.gif the phase difference i.e equation 10 in the slides above will remain the same cause no matter what the path the the closed loop integral of the curl of A remains the same. NOw what if I change it a bit, and apply a parpendicular magnetic field throughout the region and my gauge is A=(-By/2, Bx/2,0) How will the phase differnce change of the rectangular path. and what about if A=(By,0,0) which should be the same as that of A=(-By/2, Bx/2,0) |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Mar22-05, 10:16 PM | #2 |
It seems to me that since, in general, the integration is taken over a different area, then the flux will be different, (eqn. 5); and thus will result in a different amount of phase difference, (eqn 10). As to your second question; I'm not exactly sure, but it seems to me if you are going to align the axis of the selonoid along the x axis (and the path remains in the x-y plane) then the vector potential should intersect each path with the same rotation --thus no phase difference. However, I'm assuming here the electrons are not spin polarized similarly; if such is the case then [itex]\delta\phi[/itex] may reappear in accordance with some quantum relation. Creator ![]() P. S. Nice explanation of AB effect. |
| Mar22-05, 10:27 PM | #3 |
actually for the second case. the structure can be thought of inside the solenoid. cause there is a perpendicular magnetic field. IN the first case the path was outside the solenoid and it didn't had magnetic field only vector potential.
sso i think the question is how does an actual magnetic field change its phase compared to just vector potential |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Aharonov Bohm effect
| Could the Aharanov Bohm effect be a Berry Phase? | General Physics | 0 | ||
| Bohm Aharonov effect. | Quantum Physics | 1 | ||
| Aharonov-Bohm Effect? | General Physics | 1 | ||
| Parallel Transportation and Aharanov-Bohm Effect | General Physics | 2 | ||
| aharonov-bohm | General Physics | 1 | ||
