Another one of them circuit questions
  • Thread starter Thread starter NotaPhysicsMan
    Circuit
The discussion focuses on calculating the charge on a capacitor in a circuit containing two resistors (2.0 ohms and 4.0 ohms), a capacitor (9.0 µF), and a 12V battery. The user successfully derived the current (I) as 2A using the equation 12V = 2I + 4I. Subsequently, they calculated the voltage across the 4-ohm resistor as 8V, leading to the charge (q) on the capacitor being 7.2 x 10^-5 C using the formula q = CV.
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with capacitors and their charging behavior
  • Knowledge of basic electrical components: resistors, capacitors, and batteries
  • Ability to perform calculations involving capacitance and voltage
  • Study the behavior of capacitors in series and parallel circuits
  • Learn about transient response in RC circuits
  • Explore advanced circuit analysis techniques using Kirchhoff's laws
  • Investigate the effects of different capacitor values on charge and voltage
Electrical engineering students, hobbyists working on circuit design, and anyone interested in understanding capacitor behavior in electrical circuits.
NotaPhysicsMan
The circuit in the drawing shows two resistors, a capacitor and a battery. When the capacitor is fully charged, what is the magnitude of q of the charge on one of its plates?
Here's what I got so far:
So 12= 2I + 4I
Since q=CV and I have C=9.0uF, all I need is the voltage. And since the voltage drop between parallel circuits is the same then all I have to find is the voltage at the node going into 4 ohm resistor? Sounds like a good method but I can't seem to get the voltage drop.
Any ideas? :rolleyes:
okay for those who can't see the attachment because it's waiting approval:
Code:
|-R=2.0ohm-|--------|
V=12V        R=4ohm  C=9.0uF
|__________|_______|
Ok where I placed the letters is where you'll get a resistor or capacitor or voltage etc.
ugh, the code thing doesn't work so well, but the R=4ohm is in the middle branch and the C=9.0uF is at the end branch.
Ack, I got it nvm.
Easy really, almost had it too
12=2I+4I, I=2
V=IR at the 4
V=2*4
V=8 Volts
q=CV
=9.0x10^-6Fx8Volts
=7.2x10^-5 C.
Thanks notaphysicsman :)
