Register to reply
Internal combustion engine find Work transfer, final temerature...
by AndreasSpy
Tags: thermofluids
Share this thread:
AndreasSpy
#1
Apr6-13, 03:25 PM
P: 1
I have a 4-stroke,4 cylinder, 2.0- litre engine at a speed of 2850 rpm, the engine works in stoichiometric conditions and the mass of fuel injected per cycle per cylinder is 18 mg. The temperature and pressure at the start of compression 44 C and 1 bar, respectively. The engine compression ratio is 10.3:1, I need to find the:
a)Work transfer between cylinder gas and moving piston during the compression stroke, in Joule
b)Temperature at the end of combustion (in Kelvin), taking the energy content of the natural gas fuel as 34 MJ/kg
c)Assuming a thermal efficiency of 28%, determine the engine power output at the above operating conditions (in kW)
I also have the Cv=0.7, γ=1.35 and A/F=14.4
I first found P2, and then I found T2 then I found the W12. To find the Qin I used the following equation Qin = Qcomb= ηc*mfuel*QLHV where I put QLHV= 34MJ/kg, Combustion efficiency ηc=0.95 and mfuel=18mg. Then i found T3 and T4. And then i used this equation to find the power output W=Wnet*N/n Where Wnet= Qin-Qout , n=2 for 4-stroke engine , N=2850/60.
I always get the wrong results tho, do you have any idea where I'm wrong.
Phys.Org News Partner Engineering news on Phys.org
ESA investigates an alternative, environmental-friendly method of corrosion resistance
The oscillator that could makeover the mechanical watch
Engineers study bats to improve aviation travel
Register to reply
Related Discussions
Internal combustion engine? Mechanical Engineering 17
Does the Carnot heat engine law apply to an internal combustion engine? General Physics 21
Internal Combustion Engine Loading Mechanical Engineering 9
Internal combustion engine General Engineering 1
Hydraulics instead of internal combustion engine General Engineering 10
