Locus of points with distance sum =8
  • Thread starter Thread starter aisha
    Points Sum
The problem involves finding the locus of points such that the sum of the distances from two fixed points, A(0,-2) and B(0,2), equals 8. This relates to the concept of an ellipse.
  • Participants discuss the need to formulate equations for the distances from points A and B to a variable point C, and how to combine these distances. There is confusion regarding the setup and the interpretation of the problem, particularly about verifying distances versus finding the locus equation.
Some participants have provided insights into the nature of the problem and the relationship to ellipses. There is recognition of the complexity involved in deriving the locus equation, and some guidance has been offered regarding the formulation of the distance equations.
Participants express uncertainty about the steps required to derive the locus equation and question whether there might be a simpler method. The discussion reflects a mix of interpretations and approaches to the problem.
aisha
Locus of points such that the sum of whose distances from A(0,-2) and B(0,2) is 8
I plotted the points its a straight line on the y axis. I sub both points into the distance formula (separate distance formulas) and then made the eqn = 8 I squared both sides getting rid of the square root and then simplified and got
[tex]2x^2 +2y^2+8=64[/tex] I think I did this question wrong please help me :cry:
their talking about the sum of the distances from A and B. So you need to come up with an equation for the the distance from A and the distance from B seperatly, and then add them...
that sum should equal 8
to see the motivation behind this problem look up the definition of an ellpise, they even give a method to solve this problem here.
http://mathworld.wolfram.com/Ellipse.html
Here they are separately
Point A = square root[(x^2)+(y+2)^2]
Point B= square root [(x^2)+(y-2)^2]
I did make two different equations but when you say for the distance from A and from B I don't get FROM WHAT?
I added the above two equations and set it =8 and then solved but I think I did something wrong.
shouldnt I be finding an equation for the locus why am I verifying that point A's distance + point B's =8?
The distance from A and from B TO any point that satisfies the conditions you were given! i.e. any point (call it C, for example) in the plane such that if you add how far C is from A, to how far C is from B, you get 8. Stated another way: the sum of the distances to point C from point A and from point B is 8. There is more than one such point 'C'...indeed they trace out a curve, and this set of points on the curve that satisfies that condition is called the locus.
Edit: the animation on that link MathStudent gave you illustrates it very well.
Yes I see what you mean the animation is good as well but it is hard to find the equation for the locus did you see how many steps their are? Isnt there an easier way?
Sure. They just simplified the equation to a nice form. The equation
[tex]\sqrt{x^2 + (y+2)^2} + \sqrt{x^2 + (y-2)^2} = 8[/tex]
defines the locus just as well as the standard ellipse equation.
  • · Replies 17 ·
  • · Replies 45 ·
