Finding the distance between 2 charges in electric equilibrium.
The problem involves determining the distance of charge C from charge A in a system of three charges where charge C is in electrostatic equilibrium. The known distances and magnitudes of the charges are provided, with charge A at 1.0C, charge B at 2.0C, and charge C also at 2.0C, positioned between them.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting the forces acting on charge C from charges A and B equal to each other, as this is necessary for electrostatic equilibrium. There are attempts to express the distances in terms of a variable (r) and to manipulate the equations accordingly. Some participants express uncertainty about their algebraic manipulations and seek clarification on their approach.
The discussion is ongoing, with participants providing feedback on each other's algebraic methods. There is acknowledgment of the correctness of the approach, but also recognition of algebraic errors that need to be addressed. Guidance has been offered regarding the setup of the equations.
Participants note challenges with algebra, which may affect their ability to progress in solving the problem. There is an emphasis on ensuring that all terms are accounted for in the equations being used.
Ram012593
Charge A and charge B are 2.2m apart.Charge A is 1.0C, and charge B is 2.0c. Charge C, which is 2.0C, is located between them and is in electrostatic equilibrium. How far from charge A is charge C.
E = KcQ1Q2/r^2-------Electric force Formula where E = electric force, Kc = 8.99*10^9, r = radius
E=Kq/r^2--------------Electric field formula where q = charge of particle, E = electric field, K = 8.99 * 10^9
EQ = F----------------E = electric field, Q = charge of particle, F = force
Not really sure how to start this one so if anyone would help me it would be great thanks much in advanced!
Hi Ram012593! :wink:
If the distance AC is r, then the distance BC is 2.2 - r.
Show us what you get. :smile:
Ok I've tried setting the formulas for the forces equal to each other since its electric equilibrium so the forces must be the same and tried to solve for ra the radius of the first two and I am not sure if i did it incorrectly or i made an algebra mistake it could easily be both as I'm not very good at algebra at the moment if anyone would correct me this would be great thanks much:D. Here is a link to a snapshot i took of what i did so far. If i am doing it correctly which is not likely can someone tell me how I could continue. http://postimg.org/image/q4md6ins1/
Hi Ram012593! :smile:
Ram012593 said:
… I'm not very good at algebra at the moment …
Yes, your method is fine, but your algebra has let you down :redface:
your 1/r2 = 2/(2.2 - r)2 is correct :smile:,
but you left out the 4.4r term when you expanded that square! :confused:
(btw, why use two letters, ra, or maybe ra, when one letter will do? :wink:)
  • · Replies 32 ·
