Resistivity in Archaeology: A Tool for Identifying Underground Objects?
  • Context: Undergrad
  • Thread starter Thread starter Johntoby
    Resistivity
This discussion clarifies the distinction between resistivity and resistance in the context of archaeological surveys. Resistivity is defined as the intrinsic property of a material that quantifies its resistance to electric current, independent of its dimensions, while resistance is a measurement that depends on the specific configuration of the material. The application of resistivity in identifying underground objects is significant, as lower resistivity values often indicate the presence of metals, aiding in the detection of archaeological artifacts.
  • Understanding of electrical properties: resistivity and resistance
  • Familiarity with multi-probe resistive survey techniques
  • Knowledge of materials' electrical characteristics
  • Basic principles of geophysical surveying in archaeology
  • Research the principles of resistivity measurement in geophysical surveys
  • Explore the use of resistivity meters in archaeological applications
  • Learn about the relationship between resistivity and material composition
  • Investigate case studies of resistivity surveys in archaeological contexts
Archaeologists, geophysicists, and students studying geophysical methods in archaeology will benefit from this discussion, particularly those interested in the application of resistivity in identifying subsurface artifacts.
Johntoby
Hi all, I am writing an assignment at the moment, asking me to report on the use of resistivity in identifying objects under the ground.
I've gotten confused as to whether resistivity is used at all - surely resistance is all that is needed? For example, in any multi probe resistive survey, the resistance is measured between points to give a map of resistances and then show areas of abnormality. Where does resistivity come into it?
Thanks very much
Welcome to PF!
Hi Johntoby! Welcome to PF! :smile:
Different materials have different resistivity … can you write something about that? :wink:
Resistivity is a local property: specifically it is the magnitude of electric field required to produce 1 amp per unit cross section of current in the material. It doesn't depend on the length or thickness of the material, so it is a good measure of the intrinsic resistance of a certain material to electric current.
Resistance is a global property: it's the voltage needed to make 1 amp of current to flow between two pre-defined points. Clearly, this depends on where the points are, how thick the conductor is, how long it is, etc. It's typically what you measure.
Why is this useful ? Resistivity gives you clues about what is underground. If you know the resistivity is low in certain areas, then it's likely you might find some metal in there because metal has a lower resistivity. So if you put two probes either side of this metal, you'll measure a lower resistance than if you put two probes between a lump of coal!
10K
11K
