Is current used up in a resistor or the voltage is used up?
The discussion revolves around the concepts of current and voltage in resistors, specifically questioning whether current or voltage is "used up" in a resistor. Participants reference Ohm's law and the behavior of current and voltage in different circuit configurations.
  • Conceptual clarification, Assumption checking, Mixed
  • Some participants explore the meaning of "used up" in the context of current and voltage. Others discuss the implications of adding resistors in series and parallel, questioning how current and voltage behave in these scenarios. There are attempts to clarify the definitions of current and voltage, as well as their roles in resistive circuits.
The discussion is active, with participants providing insights into Ohm's law and the behavior of current and voltage in resistors. Some guidance has been offered regarding the relationship between current and voltage, but multiple interpretations of the original question are being explored without explicit consensus.
Participants note the potential confusion arising from the phrasing of the original question and the terminology used in textbooks. There is an acknowledgment of the importance of understanding the flow of current and the concept of voltage drop across resistors.
F|234K
is current used up in a resistor or the voltage is used up?
Neither.
What do you mean by "used up" that is not a term I commonly see used in this contex.
lol, that is EXACT wording of the question in my book.
"is current used up in a resistor"
What do you know about current in a resistor?
Throw your book out the window, because it is poorly written.
Resistors follow Ohm's law: V = IR. That's the most precise, and most correct statement you can make about them.
- Warren
well, current decreases if there is a resistor present, and i think voltage decreases at the same time...then it's both decreases...but i remember the teacher said something about voltage decreases. therefor, i don't really know.
What is current?
It's really just a horribly-worded question with no clear answer.
If you add a resistor in series with another, the total resistance increases, and the current drops (as Ohm's law indicates). Each resistor also has a voltage drop across (again, as Ohm's law indicates).
On the other hand, if you place a resistor in parallel with another resistor, the total resistances goes down, and more current flows, while the voltage on the first resistor isn't changed at all!
So write that down.
- Warren
well...the charge flow through something for a specific period of time...
Data said:
What is current?
The flow of charge; i.e. the amount of charge that passes a fixed point in the circuit per unit time.
- Warren
current = flow of electric charge
all power line, wire and cable carry current...
chroot, thanks a lot.
I was asking the poster :bugeye:
In RC circuits, current is always conserved, since otherwise you'd have to get a charge buildup at some point, which would quickly stop the current altogether.
...which is exactly what a capacitor is.
You're talking generally about the continuity equation for current, which holds in a purely resistive circuit. The same continuity equation certainly does not apply for a capacitive circuit, however -- there can be a current into the capacitor's leads, but no current flows between its plates.
- Warren
For Resistors (to which this question refers) in any circuit, the Current entering a Resistor EQUALS the Current exiting the Resistor (otherwise, like Data points out, electrons would accumulate inside the Resistor). Thus, there is "no loss of current" inside a Resistor.
However, when this Current "I" flows thru a Resistor "R", a VOLTAGE DROP "V" of magnitude {V = I*R} occurs across the Resistor. (The measured Voltage on one side of the Resistor will be less than that on the other when referenced to the same "zero point" in the circuit). Thus, in some sense, the situation is like "losing voltage". (<--- bad term, we're just humoring the textbook)
It's better to think in terms of water pressure: Higher pressure (i.e., higher Voltage) is required on one side of the Resistor than the other in order to supply power for "pushing electrons" thru the Resistor (which presents "resistance" to electron flow). ((This process represents electrical power "W" of magnitude W = I*V = V2/R = I2*R being converted to heat.)) In any case, the Resistor's Voltage Drop {V = I*R} is used extensively in circuit theory (e.g., Kirchoff's Laws, etc.).
thanks, xanthym. i was doing the problems and i found, just like you said, the voltage "drops", and the value is equal to V=IR
