Can an Arduino Effectively Drive a Power MOSFET at High Frequencies?
  • Thread starter Thread starter Curl
    Arduino Fet
The discussion revolves around the feasibility of using an Arduino to drive an IRFP250N power MOSFET at high frequencies, specifically around 1 kHz. Participants explore various methods and components for effectively switching the MOSFET, including gate drivers and transistor configurations.
  • One participant expresses doubt about directly connecting the Arduino's digital output to the MOSFET gate and inquires about suitable gate drivers.
  • Another participant clarifies that the Gate Threshold Voltage is not the optimal driving voltage and suggests using 10 to 15 V for better performance, referencing the MOSFET's datasheet.
  • A participant asks for recommendations on specific components, mentioning the UC3710 as a potential driver.
  • Another participant suggests that the UC3710 may be excessive for the application and recommends looking for cheaper alternatives in DIP packages.
  • One participant proposes using an NPN transistor in a common base configuration with a higher voltage supply as a simpler solution.
  • There is a discussion about the appropriateness of using a common base amplifier for driving a power MOSFET, with concerns about input and output impedance raised.
  • Participants debate the suitability of different configurations, including the use of a totem pole arrangement to improve driving capability.
  • One participant notes that Arduino digital outputs can source/sink 40-50 mA, suggesting that driving the MOSFET may be feasible with proper consideration of the load.
Participants express differing opinions on the best approach to drive the MOSFET, with no consensus on a single solution. Various configurations and components are proposed, indicating multiple competing views.
Participants mention the importance of gate voltage and current capabilities of the Arduino, as well as the need for additional components like resistors and decoupling capacitors, but do not resolve the implications of these factors on the overall design.
Curl
I want to drive a IRFP250N power MOSFET using a square wave generated by an Arduino at high frequencies, maybe 1kHz or so. I doubt I can hook up the digital out to the mosfet gate, so is there some kind of gate driver I can make/buy that will take in the square wave signal and violently switch that mosfet on/off at the proper Vgs (I think 4V for the 250N) as fast as possible?
thanks
The Gate Threshold Voltage you see in the datasheet is really an "off"-characteristic and is where you'll start to see the on-resistance of the FET begin to drop.
For the IRFP250N, a V_GS of 10 to 15 V would decrease its on-resistance substantially, e.g. they use 10 V for the test circuits in the datasheet. You should have a look at the output or transfer characteristics of the FET instead to determine what gate voltage you should drive it with.
Even for the IRFP250N, with its relatively large input capacitance, 1 kHz isn't really that high. Does your Arduino board have open-collector/drain outputs? How much current can it sink through its output pins?
You could throw in a push-pull stage yourself to drive the FET or you could just pick one of the simple drivers from Linear/TI/Fairchild etc.
I am trying to do this as well. Do you have any specific components that you recommend? How about this one: UC3710
Fairly expensive but is it worth it?
The UC3710 is maybe a tad overkill for driving a IRFP250N at 1 kHz. If price is a concern, I'd just have a look at whatever was cheapest in a DIP-package (if you have to solder it yourself).
I did a quick search on Farnell and this was the cheapest in my country (Denmark):
http://ww1.microchip.com/downloads/en/DeviceDoc/21390d.pdf
Pop that one in with a 22 ohm resistor in series with its output and I'm sure you'd be fine.
Edit:
You'd need a supply capable of feeding it and some decoupling caps, but I hope that goes without saying.
Why not just use an npn transistor in a common base configuration with a higher voltage supply?
See attached for common base level shifter for Arduino.
Low input impedance and high output impedance, isn't that the opposite of what you're looking for in a driver?
I guess you could solve it with buffering, but why not just add a matched pnp for a totem pole instead?
Are you trying to make a philosophical argument or are you stating that an Arduino can't drive a 10k load and a 51k source impedance can't drive a mosfet?
I'm saying you probably wouldn't use a common-base amplifier to drive a power MOSFET since it loads the input to charge the FET's gate capacitance.
Edit:
Having had a look at some of the commercial Arduino boards from arduino.cc, the digital outputs can source/sink 40-50 mA per pin according to their specifications, so your solution would probably work fine. I'd personally rather use a push-pull stage instead for the larger current drive and to avoid loading the Arduino.
  • · Replies 28 ·
  • · Replies 32 ·
