Electron Change & Tau Electrons at Close to Light Speed
  • Context: Graduate
  • Thread starter Thread starter michb
    Change Electron
The discussion centers on the behavior of electrons and tau electrons as objects approach the speed of light, particularly whether electrons transform into tau electrons under such conditions. Participants explore concepts related to mass, energy, and relativistic effects in the context of particle physics.
  • Some participants question whether electrons change to tau electrons at relativistic speeds, with one participant asserting that they do not.
  • There is a discussion about the concept of invariant mass versus relativistic mass, with some participants arguing that relativistic mass is not the actual mass of an object.
  • One participant explains that energy increases without bound as speed approaches the speed of light, while another emphasizes that relativistic effects are not perceived by the moving object itself.
  • Several participants express differing views on the usefulness of the concept of relativistic mass, with some defending its application in certain problems while others criticize its validity.
  • There is a mention of historical context regarding the definitions of mass and momentum in both special relativity and classical physics.
Participants do not reach a consensus on the validity and usefulness of relativistic mass, with multiple competing views presented regarding its application and interpretation in the context of relativistic physics.
Participants highlight the distinction between invariant mass and relativistic mass, and the discussion reflects ongoing debates in the physics community regarding these concepts. Some statements made are contingent on interpretations of relativistic dynamics and may depend on specific contexts.
michb
I was wondering if the electrons change to Tau electrons when an object reaches close to the speed of light. From my limited understanding, the mass as well as the energy increases to almost an infinite mass/energy. Tau electron have a heavier mass, right?
No.
When particle physicists talk about the mass of an elementary particle, it's always the "invariant mass" a.k.a. "rest mass" which is a fundamental property of the particle.
Thank you. :) Trying to learn and figured I would ask...
If the mass of an elementary particle is at the "rest" state, how does the mass increase so much when it travels near the speed of light?
It doesn't.
Energy increases without bound as speed approaches c.
In the early days of relativity, some physicists found it convenient to define a quantity called "relativistic mass", which is really just energy divided by c2, because its use made the relativistic formula for momentum look like the classical one. But, there's no sense in which relativistic mass is actually the mass of the object.
Thank you so much. I really appreciate all the feedback :)
That is not true. The thing is rather that there are some people who do not have anything better to do than to ridicule the notion of relativistic mass. But the notion is useful in many circumstances. This article explains it very well:
http://www.phys.ncku.edu.tw/mirrors/physicsfaq/Relativity/SR/mass.html
Parlyne said:
IBut, there's no sense in which relativistic mass is actually the mass of the object.
That's a bit too strong of a statement - relativistic mass is still useful for some problems. It is, for example, the easiest way of calculating the trajectory of a relativistic particle subjected to a transverse force where F=mrela works as expected. This might have been more interesting a century ago, when experimental verification of the simplest predictions of SR was still an important problem.
However this is a bit of a digression, as there's a real misunderstanding at play here:
From my limited understanding, the mass as well as the energy increases [with speed]
None of the interesting relativistic effects - time dilation, length contraction, energy increase, mass increase if you're old-fashioned - are observed by the moving object itself. As far it is concerned, it is at rest while the rest of the universe is moving rapidly in the other direction... so nothing changes for it, and OP's original question about whether relativistic effects will cause the particle to change its basic attributes is misplaced.
So basically, the article is saying that relativistic mass is useful for hiding the places where relativistic dynamics are actually different from what would be expected classically. Again, though, most of those cases come right back to insisting that momentum is mv. And, the invoking of GR is even worse; since, once you're in the context of GR, the quantity that would show up in the places that relativistic mass shows up in SR is not generically the same as γm.
The low point of the article, though, is where it claims that, in rejecting relativistic mass, one asserts that a heated object does not gain mass. This claim is, put lightly, a load of bovine excrement. In insisting that rest mass is the only thing that can validly be called mass, what one is really saying more technically is that mass is (up to appropriate factors of c, which I will ignore because we're cavalier like that in particle physics) the magnitude of an objects 4-momentum. This works just as well for composite objects as for fundamental ones; and, it will generally be the case that, in the frame where total momentum is 0, the mass of a composite object will be the sum of the energies of its constituent parts. (Well, again that's in SR; but, the basic point here holds generically.) When talking about a composite system like this, we generally call this the system's "invariant mass."
Or, we could just admit that Newton's original formulation was maybe not the best way to express the dynamical idea in the first place. Even in classical physics we can find places where F = ma doesn't work. But, [itex]\vec{F} = \frac{d\vec{p}}{dt}[/itex] will; and, it will continue to work even in SR.
I think, to some degree, that the desire to keep relativistic mass around arises from the mistaken idea that energy and momentum are derived quantities (leaving the kinematic quantities, mass, and force as fundamental), when a better understanding of physics tells us that energy and momentum are the things that really have a deeper significance in the structure of physical reality.
I don't think the last few messages are helping the OP.
  • · Replies 31 ·
  • · Replies 51 ·
  • · Replies 130 ·
17K
  • · Replies 45 ·
