How Does Ionized Water Impact Health?
  • Thread starter Thread starter shounakbhatta
    Water
The discussion revolves around the concept of ionized water and its purported health benefits compared to regular drinking water and purified water. Participants explore definitions, chemical processes, and health implications associated with ionized water, as well as the terminology used in the context of water purification and ionization.
  • Some participants question the health benefits of ionized water, suggesting it may be a marketing gimmick.
  • A participant explains the chemistry of ionized water, noting that all water is ionized to some degree when substances are dissolved in it, and describes the processes involved in producing alkaline and acidic water through ionization machines.
  • Another participant challenges the definition of "ionized" water, stating that the term is not commonly used in chemistry and that water naturally contains ions due to autodissociation.
  • Some participants assert that there is no such thing as "ionized" water, arguing that the term is misleading and that the correct terminology should involve dissolution rather than ionization.
  • Concerns are raised about the purity of drinking water, with some participants advocating for the benefits of drinking spring water over processed options.
  • Participants discuss the minimal ionization present in pure water at neutral pH, emphasizing that this does not confer any special properties to it.
  • One participant mentions the physiological implications of pH levels in blood serum, indicating that the context of ion concentration is important in discussions about water quality.
Participants express multiple competing views regarding the existence and definition of ionized water, with no consensus reached on its health benefits or the terminology used to describe it.
There are unresolved issues regarding the definitions of ionization and dissolution, as well as the implications of water purity and health effects, which depend on varying interpretations and assumptions among participants.
shounakbhatta
We often hear of ionized water, purified water. How does it help in our health? I mean to say what is the difference between drinking water and purified/ionized water.
Thanks,
-- Shounak
Biology news on Phys.org
Thanks,
-- Shounak
My personal opinion - a marketing gimmick for the people selling this product.
Basic Chemistry of "ionized" water
Nearly all water (except pure water such as distilled water) is ionized to some degree. Water is ionized any time you dissolve a substance in it. For example, if you dissolve salt in pure water, you get water with sodium ions and chloride ions in it. The water is now ionized.
The water coming out of your tap is ionized water. If you have hard water, your water contains:
magnesium ions
calcium ions
carbonate ions
Plus other trace ions
There are two kinds of ionized waters produced simultaneously by water ionizer machines: Alkaline water and acid water. Both types of water must be produced at the same time because the ionizer machine separates carbonate ions from mineral ions (calcium and magnesium). Both are discharged in separate water streams.
After separation, the calcium and magnesium hydrolyze with water to regain chemical equilibrium. The result is water with dissolved calcium hydroxide and magnesium hydroxide - this makes alkaline water.
The carbonate ions are discharged in a separate water stream. They also combine with water to form a weak solution of carbonic acid. This makes acidic water.
The alkaline water has shown a link to bone health, and can neutralize acids. Typically, it takes about 17 - 25 8 ounce glasses of alkaline water from one of these machines to neutralize the acidity of a can of soda. Studies of alkaline water for health are preliminary, and ongoing.
The acidic water can be useful for topical treatment of conditions like eczema and acne.
Define what you mean by "ionized", as the definition you used is not following the one used in chemistry. Or at least it is not following the one I am used to.
Water autodissociates, producing two ions - H+ and OH-. They are always present in water, whether it is a a stinkin' poodle or ultrapure 18 MΩ. This is what we usually mean by "ionization" when it comes to water.
Then the water can contain other ions, from dissolved ionic substances. But I don't remember hearing the process of introducing them named "ionization".
"Ionized" water is not well defined
I was attempting to explain that ions get put into water by dissolving substances in it
According to retired chemist Stephen Lower there is no such thing as "ionized" water. Semantically he's right. De-ionized water exists as a phrase, but "ionized" water is a meaningless term. I used the term "ionized" water to mean - water that has not had the ions removed from it e.g not de-ionized water.
The process of introducing ions to water is not ionization, the correct term for the process is Dissolution. I was attempting to clarify the process that the inaccurately-named machines called water ionizers use to make "ionized" water (membrane electrolysis).
Thanks,
-- Shounak
There is no such thing as ionized water. Ultrapure distilled water tastes flat and is mildly bad for you.
Much drinking water has harmful impurities that can be filtered out. Pure water is better than that. There are a number of ways of purifying it.
I drink water straight out of a spring.
Well, at pH 7.0, one part in 10,000,000 is ionized: H3O+ and OH-.
Right. But that's not very much, and water like that is more or less an insulator. Besides, all water is like that. There is nothing special about it. It's just plain old pure water. I guess you could pass an electrical current through it to ionize the water, maybe that's what they mean. But it goes back to ordinary water pretty quickly, so you can't sell it.
Salt water has plenty of ions, but that's not ionized water, its salt water. Similarly, there are lots of things you can dissolve in water to produce ions. But that's water with ions dissolved in it, not ionized pure water.
That depends on the context. Arterial blood serum is kept within the physiologic range of pH 7.35-7.45 and pH 7.0 would be fairly acidotic (as in acidosis), indicative of some pathology. It's true that endogenous buffering systems as well as renal and respiratory compensation work to keep the serum pH within the normal range, so there is some tolerance for ingesting acidic fluids. The serum concentration of H+ ions (actually [itex]H_{3}O^{+}[/itex] ions) for physiologic pH is around one part in 25,000,000.
  • · Replies 45 ·
  • · Replies 28 ·
12K
24K
  • · Replies 37 ·
11K
  • · Replies 27 ·
